2012 XR6 (Mark 2 from late 2011 onwards)
https://www.carsales.com.au/private/details/Ford-Falcon-2012/SSE-AD-5243126/?Cr=4
Or get the ex taxi on there for 2k LOL
Edited by UNR33L
Take a look at S2000 prices on carsales. Its mental. I thought evos were bad... S2000 gonna have GTR e-peen syndrome in like 5yrs time.
Prices range from $18k to $50k. With a car with basicallly no added extras
I was considering buying about 7 years ago when they weren't old as shit, thrashed out and seemed like decent sports cars for the money
Considering an Abarth Spider is nearly on par for performance, 15 years newer, more features and nearly the same price...f**k the S2000
At least the GTR has history and a marquee to it, along with outperforming that car in every way...the S2000 was the pinnacle of 2L N/A performance in 1999 and that's all it was. Honda boys are still tossing over the 9000 jerks per minute and vtec.
  • Like 1
2 hours ago, Leroy Peterson said:
*spawns satan after about 9 months
Anyone rubbing her belly like shes buddah? Apparently thats a thing, and i dont think its cool
Her tummy isn't that big yet, but that is definitely an incredibly stupid ritual
7 minutes ago, UNR33L said:
I would of kept my GTR longer if it wasn't rusty AF
Shoulda kept it anyway rust is now acceptable in R32s and soon will be in 33s lol
  • Like 1
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
