2012 XR6 (Mark 2 from late 2011 onwards)
https://www.carsales.com.au/private/details/Ford-Falcon-2012/SSE-AD-5243126/?Cr=4
Or get the ex taxi on there for 2k LOL
Edited by UNR33L
Take a look at S2000 prices on carsales. Its mental. I thought evos were bad... S2000 gonna have GTR e-peen syndrome in like 5yrs time.
Prices range from $18k to $50k. With a car with basicallly no added extras
I was considering buying about 7 years ago when they weren't old as shit, thrashed out and seemed like decent sports cars for the money
Considering an Abarth Spider is nearly on par for performance, 15 years newer, more features and nearly the same price...f**k the S2000
At least the GTR has history and a marquee to it, along with outperforming that car in every way...the S2000 was the pinnacle of 2L N/A performance in 1999 and that's all it was. Honda boys are still tossing over the 9000 jerks per minute and vtec.
  • Like 1
2 hours ago, Leroy Peterson said:
*spawns satan after about 9 months
Anyone rubbing her belly like shes buddah? Apparently thats a thing, and i dont think its cool
Her tummy isn't that big yet, but that is definitely an incredibly stupid ritual
7 minutes ago, UNR33L said:
I would of kept my GTR longer if it wasn't rusty AF
Shoulda kept it anyway rust is now acceptable in R32s and soon will be in 33s lol
  • Like 1
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
