it's looking like I'm out, brake pads took a week longer than expected,
and when went to move it sunday I was bogged, only got it out last night and no time for a brake system install.
will still turn up to help tho.
oh and bought a new gopro for the day so yeah if you want to borrow..
Can you give your spot to Chris Starr? He was keen to do it I think
Yeah but typically linked to hitting your targets.
I mean if it were real estate that'd be easy, selling to people that want to buy houses in the first place.
IT hard selling things to people that have no idea that they need it or have never needed X in the past.
Inb4 real estate agents come at me
  • Like 2
Lol.
I'll be trying to go as quick as I can with mechanical sympathy (ie. no hard launches, hand brakes)
The Falcon was horrid on the skid pan the rex should feel 10x better.
Rebuilt forged engine, rebuilt gearbox, new lsd - I’ll be going all out.
Expecting many loops and slow times haha
  • Like 2
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
