Wont it just be the same cars that rock up at every meet?
Yep but pulsar hasnt been to a big meet in... Years. Plus gathering of VIP cars who havent seen in a while or freshly imported.
Fair enough we need to do a cruise soon
Pats car should be tuned and done in 2 weeks
  • Like 1
Such a hard life Liam.
Living away from home for 10months starts to take its toll. Lots of car friends to catch up with and a back-catalogue of work to do on cars.
If you want I can hook you up with some cheap Neons to make you feel better? (proper Neons, not that LED pleb stuff)
5 hours ago, Odium said:
Whats next for you?
So after being made redundant 3 weeks ago, i had another department at work ask if I would be interested in working for them.
basically some skills I have that is not replicated elsewhere withing the company that they need.
after discussing with with them, they are building a new role around me and my skill set rather than try and fit me in an existing role.
SO still a little bit of consulting, but more training of others in different offices and having oversite on processes and procedures for some of our partners and offices.
still locking in details but going to be a fun ride
  • Like 2
Basically they gave you a heap of money to change roles within the company.
It's a win for you, bit stupid on their part though.
i've been there for a while,
the IP I have in my head is worth much more to them than my salary...
basically they loose me, they loose near on 10 Mil of revenue stream as they cannot service it.
we have 2 people left who can maintain the product globally and one who can install..
that's the 2nd redundancy that I have come though in better position for.
this one however is all on me, its up to me to either make this role work which has great potential for future, or fail miserably.
and with more exposure, gone from 9 levels to CEO to 4
Reduced levels of management above you can be a good thing.
I have one level and a side step to the ceo, the extra exposure does come with the ability to be able to tell other people to just bugger off and that what you are doing is happening and they are just going to have to get over it and move on, which is great for getting shit done. Though if you have to deal with office politics that's less applicable unless you are at the yolo end of the do I look like I give a f**k scale.
If you are in a non-dedundantable (not a word) job position bringing in revenue to a firm of $10M. Then your salary should be like $5M
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
