Nahhh Darren, no man on man here mate!!! Sorry to disappoint haha. Anyways, so Darren do autos pull all over the shop in kws? Ps. I will have more than 2 grand for modding, just over a few months or so. I really don't want to go manual-but if huge difference in kW capabilities then maybe think about it. Or try rb25/30 on auto with built box
Just so you're aware a built auto box is around the $3-4K mark just for the box and that's generally on exchange basis.
For what it's worth I wouldn't bother with a stock box, either plan to build one from the outset or buy a manual car. I've got an early model RE4R01A auto box behind a 25/30 making 180rwkw but a lot of torque (lucky to be 300hp at the flywheel) with a shift kit and the box lasted 2000km before destroying the brake band. A later model RE4R01A like what comes in the R33/R34 is a little beefier with wider bands but it'd do the same thing eventually. I picked up a stronger RE4R03A and will try that with a shift kit but if it dies I'm putting the 25DET manual box in that's sitting under the bench as I can't justify sinking 4 grand into an auto box.
Cheers XR Pilot. But damn...3-4k for 2'000 km. it's a little disappointing to hear & only 180rwkw(sorry no disrespect XR). I was hoping for a lot more, like "Satanics" r34 project-I know it was a rb26/30 but still he kept it tip tronic & hit high hp. He did have hiccups though
Im not disappointed, i like vags..
Just trying to explain to you that wilst you may be able to have the money to modify the car by doing porn, you will also probally give up the right to float wilst swimming to get it..
And the autos suck..stupid f**king lock up converter is shite ,get a th400 or glide
cheers
darren
Edited by jet_r31
Just to be clear - that was a shift kitted STOCK auto that lasted 2000km - which is why I said plan on getting a proper built auto or just get a manual car. Also it's "only" making 180rwkw on 9psi on a STOCK R33 turbo. The car was built for daily duties and I have no doubt it'd be far quicker than a 300rwkw RB25 in point-and-squirt style traffic driving. It makes over 100rwkw at a bit over 2000rpm.
I haven't read back to see if it has been asked already but what are you trying to build the car for exactly? Drags, drift, circuit racing, daily driver? Not trying to be harsh but you need to figure that out before you a) spend any money and b) decide you need a 600hp auto Skyline.
cheers
darren
hey Darren, now I know what you're talking about, powerglide & th400. know them as 2 & 3 gear upgrades. How are they for Street driving ?
Are u looking to sell by any cance? Colour, kms, condition???
I had considered selling the entire box and transmission setup if the torque converter I am getting built doesn't end up doing what I want the car to do very well
(someone may want it for a different application, i.e drag)
But in all honesty, get the manual
If you would like to me expand on it, you should really, really, really get the manual.
To expand further, the gearbox has cost me closer to 10K to get it to where it is, which is good, but unless the TC from TCE makes it better than a manual (arguable!) you're at least, least, least spending 10K to get to the level where a $0 manual gearbox is at.
get the manual
To find out floor it till it swings a leg out of bed!!! Then back off 10% to be safe!!!
A manual RB25 can take 300rwkw and still be reliable. A NEO will - superior head - do a bit more.
Having said that I have now very likely angered the gods and mine will stop suddenly sometime soon.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
