R32 Electrics Gone
sama1500
 Share
so recently my r32 was dying due to the alternator not charging the battery, i took it out and replaced it with an rb25 alternator as i found they bolt right in and can be used on the rb20, went to reconnect my battery and got a couple sparks while doing so even though i made sure no electrics were on, however connected it up and car started up first go no worries. The problem is my electrics now dont work, no interior lights, no radio, no dash lights, no windows/mirrors. the parkers and headlights/tail lights still work and all mechanical components work normally, any ideas what this could be?
Not sure if r32 would have big wiring loom running inside the drivers side front guard but i had similar dramas with r33 electrics, coz of car being too low, tyres rubbed through the big wiring loom and all the wires were melted together.
i think they do however i'm fairly sure mine has been tucked and my car isnt crazy low either, i've never had any issues with my electrics but as soon as i turned the car on with the new alternator everything stopped working
so i'm pretty sure i found the problem, main fuse completely gone lol, the one that says 75A in the engine bay, does anyone know how much current an rb25 alternator flows? im assuming the rb20 ones flow 70A and rb25 flows more than 75A
The issue is when you first connected it up with the battery. That's when it blew. The car wasn't even running.
I don't believe the replacement alternators ampage is the issue as there is not a significant difference.
Well it can draw up to 90A.
No, it PRODUCES (up to) 90A, then feeds it back into the battery. That amperage does not go through the fusible links, there is no risk that the alternator can blow the links or other fuses.
FWIW, in the "olden days", my 180B SSS ran a quite small alternator - about 45A. Because it used 100W Cibie driving lamps in "rally car" trim, the alternator was upgraded to about 80A, with no other modification to the electrics, and no problems with fuses blowing. Such an upgrade was quite commoin in rally cars of the day (70s, 80s).
  • Like 1
the only problem was the power cable that looked like an earth, on the rb20 its too small to fit on the rb25 nut so you have to cut it and put a bigger one on, other than that its perfect fitment so i'd recommend it to anyone who's electrics seem weak
 Share
    • Me too. Apparently the new version of Invision will allow some customisation so look forward to a 'Love' reaction and a new 'Like' icon.
    • Which injectors are you using? It's likely the fuelling is off also, so as above.
    • Awesome to know. I have a Series 1, and When pulling my front bumper off for the first time i realised my reo/crash bar was a bit worse for wear, and was going to try pick up a better one soon just so i can replace it. Someone is selling a full series 2 front bar and brackets for a decent price, so was going to probably reuse my brackets and install the new second hand reo/crash bar. I also have a genuine Altia body kit to do up, spray and put on, and not sure if that will use the series 1 or series 2 brackets for the front bumper, so having both will be handy, and knowing i can drill holes out to make stuff fit between series is also handy to know!
    • I should also say that the while they are different the only parts that matter are the center headlight supports and center bar from S1 to S2. The center bar will work, but the S1 has holes that clips go through into the S1 bumper. So if you were super cheap you could simply drill the S2 bar. Same thing with the side/wings. They have slightly different 'clips' but can be made to work. The center headlight brackets however, cannot. This is also where the GTR differs, which has a different center bar, and different headlight supports (to either GTT system), it also has different 'wing' headlight supports which is what I am calling under the headlight. However those CAN be made to work with the GTT Reo for a GTR front bar by a small spacer and a drill/tapping a thread into the reo because the bolt positions are slightly different. So people only really need the center brackets to go between GTT S1, GTT S2, and GTR if you are happy to do some tinkering.
    • Indeed  😃  Appears the site is back up now (migrated not updated) - kudos @funkymonkey & @PranK
