Hi guys can you guys help me out. How much am i looking at to turbo a stock N/A 2.5 neo 25gt4
1. Can you guys list me down all the things ill need and how much they will be and also how much installation and tuning will cost
2. Does a turbo kit come with everything Ill need ? or will i have to shop around for each individual part ?
3. Is the N/A 2.5 neo the same as the turbo version in relations to how much boost they can handle before internals need upgrading?
I have around 10k to play with can you guys give me a rough idea of what kind of power I will be looking at after everything is finished?
I will be looking at a bigger turbo then a stock neo version would like to have around 250-300rwk if the stock internals can handle it.
I know I'll be looking at around roughly $2k - 2.5k for a ecu and tuning already so will $7.5k - 8k be enough to get everything all good to go ?
Thanks in Advance.
Edited by Kei_ayanami
https://www.sau.com.au/forums/topic/459576-cost-to-turbo-na-25gt4-25-neo/
What you need.
1) a camera (phone will suffice)
2) a computer (phone will also suffice)
3) $50
4) post photos taken from phone or camera onto carsales via computer or phone
5) buy gtt/gtr by utilising phone or computer which has been previously acquired.
For $10k you should be able to buy an RB26 c/w gearbox and ecu (actually a half cut should get you the FMIC etc and if you are lucky the brakes as well.
Then you can update the brakes suspension and tyres.
Thanks in Advance.
I have a mate that bought one of these for a track toy, he put an RB26 in but reckons in hindsight he should've gone an RB25/30. You might be able to build a budget one for that around about that sort of money if you don't go for forged internals and all the fancy fruit.
Either that or get an RB25 out of a Stagea - wouldn't advise the 26 route though, too much stuffing about with wiring looms etc.
  • Like 1
Neo from stagea. Expect headaches with tons of random shit.
You are asking all the right questions, which means you will come to the conclusion that it is a bad choice.
Walk away - get gtt for rwd with a fancy aftermarket traction control for grip, or go gtr.
Path less travelled for a reason.
Source: travelled the path
  • Like 2
I am currently putting a Stagea Neo rb25det into an R34 gt four sedan...
Mainly because I really want a sedan, as well as 4wd.
The guys are right, there are a lot of things that will need to be changed, which you just get included with a GTT or GTR. If you really want to do it you need to swap motors - the stock gt4 Neo motor internals are not up to the task, you need a factory turbo motor.
The only scenario where it MAY be worth it, is as above, you wanted a 4 door 34 (for the shape?), cause R34 GTR is very pricey.
But the smarts is go sailing with a R33 GTR if you can, its just seriously the better option for reasons you don't know until you're like "oh shit why did I f**king do this holy f**k"
There's a lot of debate on these forums about how to approach a lot of different things
When EVERYONE says "sell the car and buy the proper platform" then yeah they're doing it for a reason
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
