Hello
I have a R32 GTST with a RB20 DET.
I am planning to build the engine but before I do I want to get some info on the RB25.
What are its strengths and weaknesses?
How is it when put into a R32 GTST?
What are the pros and cons of putting that engine in a R32 GTST?
There have been literally millions of words written about this. Do a basic search first.
Ive done a search, I want to get up to date experiences. I spend about 8 hours plus research this on many sites.
Not just that, but we've all been saying it to Yoshii since he emerged, and those experiences are definitely up to date. I only did my Neo32 transplant a couple of years ago.
f**king awesome.
Edited by GTSBoy
f**king awesome.
I read some things about the RB25 and I thought I read several places that something about the oil pump or something to do with the oil that the RB25 has trouble with more compared to the RB20. I've actually heard a few people where I live mention the 25 is not all of that and its keep what I have or go RB26 or GTR(This is from tuning shops also). So I want to hear from people who have the engine in their car and who has done the change so I can ask about how it drives, speed, etc. Reading old posts from years ago(which I have) is not going to completely help because I am not going to try to PM someone or reply to a 2-10 year old posts.
I dont know how to express my laughter at that post. What an outrageous response.
Implying that there is not enough documentation about a) how the motor performs and b) WELL KNOWN oil issues
Its almost the single most popular conversion ever
HAHAHAHAHAHHAHAHAHAHAHHAHAHAHAHAH
Maybe you don't understand, I am wanting to speak to someone here and now so I can ask that person hear and now. Maybe I have specific questions about the engine or their experiences with the engine, what problems they may have had, what things that helped them, etc.
I reckon I'll be buried with mine..................gunna be crowded though, already have two motorbikes to throw in as well. Any vehicle that can be pushed as hard with a standard motor - such as the humble RB25 or 26 - to the point where you can get more than twice the power output for every day reliable street use for stuff all $$$ and TBH minimal mods deserves respect.
I honestly cannot see the point of your thread.........but its a free world until you shoot someone!!!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
