Hey,
so i've had this gtr sitting on my front lawn for about 3 years. I stupidly bought it without seeing it. the guy said it was running etc.
but when it arrived here on the tow truck,i tried to start it ( needed to get it off the road into my drive way ) , the battery was dead. so tried to hook up a random battery from another car.it started briefly. and ran very rough and wouldn't idle and would die after a few seconds.also have a suspicion one of the injectors wasn't working,the plug on one of them is loose and comes off too easily, and when i tried doing injector test using vipec software that one wasnt making any ticking noise like the others ( now only one makes a ticking noise during the test years later). then realised the fuel tank was empty ( rookie mistake,just wanted to get it up the drive way,was very dark too and couldnt see much) and my mate that was connecting the battery hooked it up wrong and sparks went everywhere.
car hasn't started ever since. it used to crank but wouldnt turn over.
now,obviously im a complete NOOB and got way in over my head buying a car like this.
would really appreciate some help.
specs of the car :
RB26
T04R Single Turbo kit
Stainless Manifold,
60mm Tial Wastegate
Tomei 260 Poncams
Tomei adjustable cam gears
Sard 800cc Injectors
Sard 280ltr Fuel Pump.
Gates timing belt.
R33 oil pump
Braided fuel lines
Vipec ECU
i know this is all a little vague but i'm not very mechanically minded. have just ordered some tools, such a car jump battery charger,noid lights,compression gauge,fuel pressure regulator with gauge,test light ,multimeter and some started fluid to attempt to figure this out.
please ask any questions that are necessary to get to the bottom of this.
any pointers,tips etc. much appreciated
also ,forgot to mention that i accidentally reset the ecu settings and i have no idea how to set anything up ,but i tried using the stock computer and it still wouldn't start
Hey,
I can't really help you in detail, I'd recommend flat-bedding it to a reputable workshop, but some basic things that come to mind:
- You've probably blown many fuses from this, so check them all
- Start motor could be seized, may need a hit with a hammer, may need a new one,
- fuel is obvious, but pump could be seized or lines could be clogged, injectors could be clogged, (some or all of these can be cleaned or tested?)
multi-meter will be your best friend in troubleshooting
If you've reset the ecu, chances are once you get it ticking over it still may not even start, or it may run very rough, someone with Vipec experience may be able to confirm this (base map?), either way you'll need a tune pretty quick.
thanks for the quick reply. all the tools i've ordered off ebay so when ever they come i'll start looking over in detail.i did look at the fuses years ago and all looked to be ok,but i never tested with a multi meter.but that should come any day now. my first thought was blown fuses though.
ok dumb question number 1. where is the starter motor located ? i should probably just do a search but i've spent hours reading up on how to diagnose an engine that won't start, so far i've learnt to check for spark,then check compression,then check fuel etc.
i would love to have it looked at a workshop but i haven't had work in awhile so money is tight atm lol. i just want it started so i know its worth getting on the road
as for Fuel pump, it does prime for a few seconds when ignition is on. would it do that if it was seized?
not sure on how to clean injectors but i'll look into it. injectors should be easy to take out i would assume?
one more thing that just popped up from memory,when i did start it when i first got it ( when it started,barely,ran rough then died) it was making loud screaching noises,assuming was timing belt. not sure if that has anything to do with it.i might take the timing belt cover off and take some pics if needed
Sell the car. Could cost you lots of money and time to get it running. If you don't have any idea of what you are doing that could be an interesting experience as you might cause more damage.
If you want to get it running and working, going to cost money and there would be many things you'd look at doing if the car has been sitting for 3 years.
if i was going to sell the car i would like it to be running first.selling it as it is i wont get shit all for it lol. i'll just go step by step and if i still cant get it running i'll wait till i have some money coming in and get someone to take a look. but for now i think its worth a shot trying to figure it out.
my aim is to know what im doing before i attempt anything,thats why i'm asking questions on here.
any advice is welcome
becareful 3 years of sitting - how is the oil situation?
How rusted up are the fuel lines and fuel tank after sitting there with no fuel in it.
I heard of a GTR that sat for some time and new fuel lines need to be run plus fuel pump etc. Before a tune and it was going again.
I would say.
1) Fuel tank replaced
2) Fuel pump
3) Fuel lines
4) check fuses
5) Dont start it
6) Replace oil
7) Make sure engine has not seized.
8) Take to someone who knows the ECU.
Sounds like you have alot of work to do :)
To be honest if you have no budget and don't know where the starter motor is it will be all uphill for you.
Some things you could do (not necessarily enough to get it going):
Disconnect the fuel line and run it into a bottle and turn it on to see if a good supply of (fresh) petrol comes out. Then remove the filter and cut it open to see how much cr*p is in it.
Remove the coils and give them a good clean (search for instructions). Remove the spark plugs - they will probably need replacing - other wise clean and regap. With the spark plugs out try and turn the motor over by hand (or with the starter if it works). When and if you get the starter working do a compression test.
Remove the injectors and get them cleaned and tested (this will cost - there is no way round it).
Try and track down the last person to tune the car - they may still have the tune on their computer and may be able to reload your Vipec (if it hasn't been fried).
There is lots more you could do but these will take you a while!
all part of the fun lol :/
before i put fuel in it i'll pull fump out and look in the tank and see what it looks like.or do i really need to pull out the fuel tank? if its rusted or whatever could it just be cleaned?
not sure how to check fuel lines. i'll google that lol.
i bought some fuel injection cleaner thinking that will clear out the injectors of theres anything clogging them up? least i hope thats what it will do.
how do i go about making sure the engine isn't seized ?
the car had fresh oil the day before i got it. i checked it at the time and it was definitely new oil. i checked it just now and the oil is fairly black but not completely.smells normal if that makes a difference.wasn't all that thick.
any little things i can do now before all the tools etc. come ? i could probably check the fuel pump if thats worth doing before checking spark etc. ?
cheers kiwi lol yes definitely an uphill battle.just haven't googled starter motor yet. focusing more on the spark and checking fuel related problems so far.
i think the first thing on my to do list is to have a peek into the fuel tank. its on empty, must of evaporated over time. but ill see if it looks filthy or what not. anything else to check while fuel pump it out ? probably not much point till i have a multimeter ?
fuel tank wont be rusted as its plastic in a gtr but the lines could be. fuel, just lik eoil and brake fluid will start to hold water/ separate, congeal so on. it then rusts the components around it. everything will be ceased to a point. you are best to strip the motor down atleast to the point of all pumps, lines, coilpacks, plugs belts ect and turn the engine over by hand to see if you get resistance.
this is way before ecus and fresh fuel ect. do a major major service and inspection at very least.
  • Like 1
ok well here's another dumb question. how do i hand turn it? i have an idea but i like to be sure i'm doing the right thing. is it enough to disconnect the cas,spark plugs and injectors to hand turn it ? i feel like a dumbass asking what are probably obvious to most. only one way to learn :)
i know lol, the car i had before that was much simpler.although it was turbo also. u13 bluebird attessa.
i did say i was a total noob when it comes to the mechanical side but i want to learn so i get this bitch started !!
i had a quick look trying to find the starter motor but its fkn hard too anything looking similar to the pics of a starter motor i found on google. is it near the oil filter by any chance ? closest thing i found was somewhat close to it but its hard to see it.
also about the turning engine by hand. fill me in please. i dont want to be a noob anymore lol
as for turning the engine by hand,i turn it using the crank pulley? which i'll look for tomorrow.i have a big radiator and there isn't much room.will make it a pain.
EDIT: ok so i went outside and had a quick look. if that is the crank pulley (under the fan ) then it looks like i'll have to take off the radiator. will the fan have to come off too ?
is there another way of turning the engine by hand ? might sound stupid,but would putting the car in gear and jacking up the rear end and turning the rear wheels turn the engine over ?
Edited by deprived777
Oh dear, you really have bought the wrong car
I agree, in GTR circles we have a saying, "Anyone can afford to buy a GTR but very few can afford to keep it".
Ill start the offers at $6K :)
  • Like 1
i know,i have learnt the hard way lmao but i don't completely regret getting it. best way to learn is through experience. and the gtr's are my all time favourite cars so its worth the hassle in my eyes :D
keep the help and tips coming guys :)
Mate get learning. Good on ya for trying. But get as much help as possible. Read heaps but i would get a mechanically minded friend or a mechanic to guide you. Pay them for their help but do as much as you can yourself. Remember pulling shit appart is easy. Putting it back together is hard. Harder the less knowledge you have.
But hey baptism by fire why not.
Baptism by gtr fire..... keen.
My gtr cost me 2000 in its first month and thats didn't even take me off the road :P
I havnt had any major issues yet but their not cheap for anything.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
