This thread is a train wreck. I approve.
Pics of RB20 coilpack setup.
Pics of compo received for the time (4 hours) it took to take maybe 10 bolts, some plugs and replace 6 spark plugs.
Edited by iruvyouskyrine
I bought a set of the same spark plugs just in 0.8 now it better fix it now i got a spare set of bcpr7es -11 if anyone want to buy $10 let me know only 100km used. Btw if this doesnt fix it im gonna link it hard
f**k YES i figured it out and it was the MOST STUPID REASON WHY!!! YOU WILL NEVER GUESS...
are you ready....?
ONE OF THE f**kING SPARK PLUGS WERE CRACKED INSIDE THE CHAMBER BECAUSE I MUST OF OVER TIGHTENED IT!!!
REALLY?? AND GUESS WHAT, as i was putting one of the new spark plugs in, I ALSO CRACKED ONE. So i put one of my old spark plugs from before i did the service back in. So tomorrow im gonna have to go buy one more spark plugs
f**k me im stupid, who would of thought tightening these spark plugs would make the white part crack??
seriously i wasted $50(coilpacks) + $60(coilpack loom) + $35(new set of spark plugs)+ the time spent travelling and the labour.
Learn this lesson from me, NEVER overtighten ANYTHING!
  • Like 1
You didnt crack it from overtighting it, you cracked it because you didnt hold the socket straight at some point while tightening.
If your holding the spark plug properly and tighten hard enough you will strip the threads in the head and the porcelain part will still be fine.
  • Like 2
this.
i was using the extension bar and it moves around the socket a bit. I got up to the third cylinder before i cracked it. I hope i didnt over tighten the first 2 cylinders...
a rubber insert in the long socket helps keep the spark plug central and will avoid cracking.
my god i have one with a rubber socket but i didnt use it, i think because the spark plug didnt go all the way in or it would get stuck in it.
When putting new plugs in, bottom the plug out in the hole by hand with a extension, then tighten 2/3 to 3/4 (max) of a turn extra.
So run them in till they reach the end, then tighten the last 2/3-3/4 turn more.
Just use your left hands fingers to keep the extension centered while the right hand turns the extension.
  • Like 1
man i feel so stupid because i even cracked one of the new ones and i think little bits of plastic fell inside the head....someone please call me stupid
because it would make me feel better :glare:
Stupid,stupid,stupid. You asked I delivered. Feel better now :)
  • Like 1
i'm pretty sure some awesome dude who knows heaps about european porn...I mean, cars...said
"spark plugs don't like being dropped. A cracked ceramic insulator can cause ignition issues"
spark plugs are one of the few things I use a torque wrench for, would suggest you do the same until you get the feel for them, or follow gtrpsi's guide above.
i'll also just say, I like your attitude, seriously. You were prepared to have a go at it...ok, f*ked it up, but, acknowledged your mistake and have learnt something in the process. As long as no major damage caused, not a bad result at all. Although, I you're seriously concerned bits of ceramic fell in the cylinder and you haven't run the car yet, pull out the plug and use a vacuum hard up against the hole, vacuum out any bits of insulator in there.
are you ready....?
Lesson is if it was fine before you touched it, then it's you.
It's always easier to blame everything else first though.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
