Project MU aren't that noisy..
if..
shims are clean
shims have that anti squeal shit
rotors are perfectly flat
I recently installed 350Z Brembos, they don't come with shims OEM.. can't wait to drive on them.. will be squeal city. Lucky Project MU sell the shim kit for 350Z and R34 Brembos.
Nothing positive. Chasing a boost leak ATM. The turbo isn't holding boost the way it used to in the top end anymore. It used to hold 17.5-18psi and is currently only holding 14-15psi. It will make full boost with a pod but not with the airbox back on. Used to be fine with airbox. I will be removing the upper intake manifold this weekend hopefully to replace that gasket and check all those little hoses down there. I will update with my findings.
This is the same findings I had with my factory airbox, Pod filter on its fine. Everyone said the factory box is shit. Could be just a dirty filter though, no? My panel filter is filthy too
Filter is clean. Apexi panel, I have also tested with a BMC and k and n I have laying around. Same result. There is something else going on with my car because I never had an issue with holding boost before with the stock airbox. I'm suspecting the upper intake manifold gasket which I haven't had time to replace yet. Obviously the pod filter does flow slightly better than and unmodified stock air box and therefore is allowing the turbo to hold boost better although there is a problem somewhere. I find the sound of the pod to be hideous and annoying. Air box is my preference, just gotta track down the source of my issue.
If you take the plenum off check the two half's are flat and not warped, my R33 plenum had a bow in it and a new gasket was not enough to seal it, and tightening the bolts too tight makes it crack, lesson learnt here..
Edited by AngryRB
Get someone to smoke test it. At least that will stop you replacing things that is not broken
I want to replace that gasket as a maintenance thing. They do tend to fail on 25's and its a 20 year old part now so I might as well do it. Its not a 26 so I don't need 300 hours to take the plenum apart[emoji12]
Thanks for the heads up. I'll check it with a straight edge when I finally get around to doing the job.
I may have found my problem. I blocked the bov off, just to rule it out and since it was quick and easy to do. Boost is now building up quicker, faster, harder and is holding up top perfectly. Just got to put the airbox back on and verify. If its all good then I will have to decide wether I continue driving around like a full hectic uleh, doseing and fluttering everywhere or getting a new bov.
get longer FMIC piping LOL... add additional longer sections for no reason
I might make some piping to go all the way to the back of the car and then do a 180 and come back. Ya reckon that'll do the trick[emoji1] lol.
10 points right there, time for some chap laps!
Remember to slightly hold the brakes down for maximum dose
  • Like 1
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
