Hey Bill,
I'm curious as in how do you mount the Adaptronic ECU?
Is it mounted where the stock ecu resides in?
Hey Grant, yeah it lives in the same location as the factory ecu. I just had to move a couple of relays out of the way and drilled one hole to mount it where I wanted it. Plastic foot well cover fits over it and hides it nicely. I'll take a pic when I get a chance and put it up.
Hey Grant. Here's the pics. I used to have it the other way so the loom plugged in from the right but it didn't leave much room for the USB and wideband input, I ended up snapping the USB port off. Adaptronic was very helpful. This way gives plenty of room above for those inputs and it fits nice and neat, the cover also fits back on perfectly. I did also relocate 2 relays. Im not sure if the GTR is any different but I guess you're going to find out pretty soon. bf0b7a751511ce4c812c408582c7417e.jpg7af54f6f57fa41d2e78baf2b3d5ba078.jpge49da880cdb1f1daf82c1cd50492fbc4.jpg
  • Like 1
Thanks again Bill.
I've sussed out another solution last night.
Take apart brackets from stock ECU and then I compared it to both Power FC I have and stock ECU with Adaptronic, width is the same and it mounts like stock ECU do.
The plan is to velcro strip to hold it together, see how I go.
Thanks again.
I shaved off the tabs and used the OEM brackets and drilled into it.. works a treat however the rear USB plug sits against the firewall padding.. but using a 90 degree USB plug work "ok".
I too snapped off my USB plug, but I managed to solder it back and then applied 1000000000x coats of super glue to it LOL
Super glue ftw. In my case I burnt an led while trying to solder the USB back on. Oops. The guys at adaptronic came to my rescue. Absolute legends.
oooots!
need Plazmaman cooler [emoji4]
That would be nice but its probably worth more than my car, lol. AWD would be nice too, that ain't gonna happen either. Can't afford any more mods, too busy pumping e85 in the fuel tank and helping United make massive ethanol profits[emoji3]
  • Like 1
Probably could get a generic 76mm pro series core at a good price :)
Holla if you're ever interested.. also can get good prices on DBA rotors, Hel lines and especially Intima Pads!
Probably could get a generic 76mm pro series core at a good price [emoji4]
Will deff keep you in mind[emoji106]
New tyres fitted this morning. Buy 3 get 1 free. Fresh 2016 production 265/35/18 AD08R. Thank you Mr Yokohama and Mr Bob Jane for the excellent pricing. Definitely an improvement over the Achilles 123S which weren't bad but just did not last.
5ad634137e67d3ac5e5748a727a270b3.jpg3bc9baccfeb313bec573f8bb60ceb336.jpgfc099c1922eee1e2f496ab54e38783ae.jpg
Looks awesome! Do you drive this daily?
Yep, driven just about every day and at every possible opportunity. I thought about putting a baby seat in the back so I could drive it even more but stopped short on that idea[emoji3] . lol
shit got real when you daily some AD08s lol
At $263 each fitted. I can afford to daily them. Got to try to get the power to the ground somehow. For that price, I'd choose ad08's every time. Sadly it is very rare, I think the guys at Bob Jane may have even f#*ked up with that price but I sure as hell wasn't going to question it. I couldn't say yes any quicker actually[emoji12]
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
