On 10/12/2022 at 12:50 AM, Kinkstaah said:
I am sorry, antilag is not part of the 'Sensible 300kw package'.
Shhh, lol.
On 10/12/2022 at 6:27 AM, Dose Pipe Sutututu said:
Lol it is, just too much retard in Bill's case.
Never go full retard, only half retard.
(Single digit ignition retard numbers for next turbo lol).
Yes I'm partially retarded but commo bogan turned me into full retard momentarily.
I think i had set it at - 40 to 45°
The other thing I didn't mention is the 2 step part (rev limiter) which is set at 3500rpm didn't activate. So she revved pretty good. Probably my dodgy wiring.
It is also possible the turbo bearings where on their way out. Anyway turbo is off to hypergear. We'll see what Tao says.
  • Haha 2
1 hour ago, admS15 said:
Shhh, lol.
Did you tune this yourself, testing at say 0 degrees, then -5, -10, -20, -30 constantly screaming more bangs! and laughing maniacally?
I hope so lol.
  • Like 2
  • Haha 2
On 10/12/2022 at 9:01 AM, Dose Pipe Sutututu said:
Whoaaaa god level lol..
Sensational bang bangs
The bangs where quite good when the rev limiter was active. I just went and double checked my settings was 10% enrich and 35° retard. Pretty sure with the adaptronic that's not absolute. Eg if base timing is 15° advanced then -35 is 20° retarded. Correct me if I'm wrong sir.
I hope so lol.
Of course I did until my across the road neighbour came over yelling and screaming, had to drive to somewhere secluded to continue. -35 was where I settled and was producing 10psi on the 2 step.
The problem here has been the limiter not activating and the turbo making a shit load more boost and heat than 10 psi would.
  • Like 1
Anyway turbo was dropped off earlier. Tao had a quick look, bearings are still good and he believes either something went through the engine, like a spark plug tip or some sort of debris. I'm just hoping it's not a bit of piston like in dosepipes. Going to check the plugs and do a comp test when I get a chance.
The other theory is excessive heat produced due to tiny 21u exhaust housing and erm anti lag. I'll know more once it's fully stripped.
He's trying to convince me to moving to a op6 housing with bb core. At this point I'm still wanting to stay with what I had as I couldn't be bothered with redoing my water lines, oil return and retuning again but I may change my mind.
You are correct sir!
Been a while since I've tuned an Adaptronic!
And I hope it's not bits of motor that smashed into your turbo, we know how that ended for me....
  • Like 1
Spark plugs removed and inspected, all tips present. Compression test done and still have between 150-160psi across all pots on a cold engine. Pretty happy with that.
Was panicking at one stage when testing cylinder 5 and it showed 90psi, retested and got the same. Was already calculating cost of rebuild and who to go to but after removing and refitting the gauge it read 150psi consistently. Phew, crisis avoided. Gauge tube mustn't have seated properly.
Unless hypergear finds bits of motor inside the turbo then I'm confident the engine is still healthy and will put everything back together.
  • Like 4
Turbo is back. New turbine and fresh bearing pack. Thanks to Tao from @hypergearfor getting it done and back to me in 3 business days. Awesome service.
Overnight parts from goodstate via ebay plus. Have used them guys a few times for genuine Nissan bits and they always seem to have stock and ship fast. Anyway, had a bit of an oil leak from an aftermarket exhaust side rocker cover gasket. Changed both with genuine + fresh half moons with a dab of threebond while I was there.
Also did a bit of degreasing to clean up the leaky mess.
Will hopefully fit turbo tomorrow morning and then boost off into the sunset. Antilag switch will most likely see the inside of my garbage bin.
  • Like 4
Went well this morning.
Home
And finished product. Oem, it's stock standard officer.
All back together, filled with fresh nulon coolant. Bleeding not required thanks to the ling long swirl pot/breather.
Managed to fire her up and check for leaks. Thankfully there where none. Engine sounds happy and the horrible turbo whine is gone. Success, sadly there was no time for a drive. Off to do family stuff with the wife and kids. Hopefully take it out for a thrash/test drive later tonight.
  • Like 4
On 17/12/2022 at 5:57 PM, Dose Pipe Sutututu said:
Ready for Christmas skids ho ho ho
Just came back from test drive. Can confirm does good skids, spins em off the throttle in 3rd.
Coolant temp was fluctuating a bit and running 5 degrees above normal. Probably some air still working it's way out of the system. Will check coolant level tomorrow and keep an eye on temp. Happy to have a functioning boat again.
  • Like 1
Lol, c'mon man. It's only a fan clutch. You've got a long way to go catching up to Greg.
In other news, checked coolant level this morning. Took another litre and a bit. Went for test drive 2.0. Temp is a rock solid 88° now as indicated by the Android gauges.
Gave her a quick wash/hose down for Christmas. Scrubbed up alright for an old girl.
After driving again and checking the peak boost levels on the boost gauge, it appears to be down by a bit over 1 psi. I do remember when removing the turbo, the actuator looked a little bent and was almost touching the outlet. I had filed down one of the bolts in the past for clearance. When the turbo came back the actuator looked perfect. I think Tao must have noticed it and straightened it up and this is possibly the difference in boost. Not sure if I'll tweak the boost control myself or take it back to Trent for a proper check and tweak.
  • Like 1
Drove through a booze bus today, Cop was all "Does that have a 25 Neo in it?" Said "Oh no, it has a LS" and opened the door and pointed to Engineering plate and told him it was all above board officer.
I got a solid thumbs up.
no RB can have that peace of mind! 😛
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
