  • 2 months later...
Update time:
Took out the floating barge shit box to Wakefield with the same tyres, same alignment just a new turbo setup and better front brakes.
Managed a 1.11.05 according to the Q-Starz. Pretty happy, my other mate (more experienced driver) did a 1.10.02 and not to mention it was his first time behind a floating pile of shit R33.
Pretty happy with the performance of these coilovers - however I sense I need some form of basic aero at the rear because I can really feel the "sloppiness" when I lift off into turn 1. Driving my mate's 180SX with a basic front splitter and a massive Voltex wing it feels so much more planted around corners albeit he actually has softer springs too.
No real warscars this time, just:
  • drove home with metal to metal rear brakes (had to shift down to stop like a mad man to reduce braking usage)
  • snapped off an exhaust bolt after I ran over a fire hydrant hose on the freaking track
  • new dead bugs and more rock chips lol
For next outing:
  • GT-R wing
  • New rear pads, will be going Intima Type-D rears to match the fronts
  • New bucket seat, my current Brix 1.5 doesn't hold enough
Hey Johnny - Curious to get some more info on height adjustment if you're willing to share.
I read on their old website somewhere that they recommend adjusting the spring perch (which would effectively change the spring preload) Is this correct?
yeah easy man!
yes they recommend adjusting the spring seat to adjust the height of the car.. I believe they recommend this to 1. pre load the shock so you're not always at the top of the shock stroke and 2. you won't bottom out the car.. the car would essentially hit the bump stops instead of the ground.
so the free play experienced when the car is lifted is quite normal. Japanese and decent Bilstein, KW, etc.. all have helper springs to avoid the free play/spring drupe.
  • Like 1
yeah easy man!
Makes sense! Thanks - Guess this is why my non base height adjustable pedders have that helper spring on it (which after 8 years is now essentially useless - They are cactus now)
Pedders = BC BR = Blitz ZZR
They're identical... however not sure if the valving is identical.
Have been in both BC BR and Pedder equipped cars and both felt harsh considering both were your run of the mill 8/6kg flavours.
MCA even advise me to get softer, but I ended up with 10/7kg but I like it very much the way it is. I've dropped both ARBs to the softest setting and utilise the stiffer springs to reduce the roll. Car feels very compliant on the track and when the dampers are clicked back for the drive back home they're honestly just as comfortable as my old Bilstein shock/spring combo (of course hitting a pot hole or running over reflectors aren't as comfortable but you get the idea).
Ahhhh - yep they are very harsh but these are the old ones, not sure if they are the same. I have the receipts for them at home too from the old old owner and they weren't cheap either.
That's the new Pedders stuff yeah? I thought the old 'package' they sold were Monroe dampers and whatever springs they had.
Mine are the old ones, so they may be the Monroe ones. Either way, horrible suspension.
  • 5 weeks later...
UPDATE time betches!
  • Car doesn't dose well anymore (new turbo)
  • Car has literally no traction now (running normal street tyres, Nitto NT05)
Anyhow enough of the silliness, last night was the first time ever I have taken the R33 shit box on Parramatta Road with the MCA X-R.. at first I thought I would pop a few discs out of my spine however it was quite the opposite. As the car is now being used for more daily use (gave our daily to the missus' sister) it's on 98RON and also has a set of Nitto NT05 on 18x9 wheels... no silly stretch or poke homo shit too.
Front dampers were set to 3/12 and rear dampers set to 4/12. Very surprised that the ride quality was decent, considering i'm on 10/7kg springs which are considered a little on the stiff side. I would dare say it was more comfortable than the basic Bilstein Shocks & spring combo I had on the car before.
So there you have it, you can have comfort and handling all in one package.
  • Like 1
Good to hear! My X-R arrived today so this is comforting to hear.
Oh wow, 3 & 4 are quite low. Have you gone for a run on a stiffer setting to see if theres any major differences?
Yeah I usually drive to the track on 5/12 front and 6/12 rears with about 80L of extra fuel ontop of the 60L in the tank + 2x semi wheels (I drive down with front street tyres and rear semis) + a full tool kit lol.
It was on the spongey side, but not crashy and floaty.. still very composed.
  • 2 months later...
UPDATE TIME CNUTS!
So went back to Wakefield Park again yesterday and managed a 1m09.6s around the circuit. Only difference this time was a GT-R rear wing, set to 3/4 setting (nearly max angle) and only fekkk the rear end grip changed dramatically!
No more dori dori across the track like a mad man. Everything else remain the same.
  • Like 1
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
