My cams licence has expired any chance I can get a day licence for the day as funds are running low and just found out car needs a wheel bearing and an alignment before the track day
Hi Jason,
Come & Try CAMS Licences are only available to competitors who are new to motorsport and have never had a CAMS License before. So you'll need to renew your CAMS License in the standard way at http://www.cams.com.aubefore the event date. If possible do it asap, as it sometimes takes a few days to send out the new membership cards in the post.
So what are the entry requirements for the social sessions? Do we require a helmet, fire extinguisher, anything else?
Same as the timed sessions.
Clothing ankle to wrist, fire extinguisher in the car, helmet.
Im in, just entered. A lot of smooching has occurred of the past few weeks to get approval from the boss to attend. My car has been prepped and im eager to get out there, have some fun and see if I can match or beat my previous PB set in my S15. This will be the first proper test for my 33, hope she passes with flying colours. Looking forward to meeting some of the SAU crew.
  • Like 1
As 33's are a bit heavier and Sandown is a brake killer, make sure you have plenty of pad available for the day and remember that you can slow roll around the carpark out the back if you don't get a chance to do a proper cooldown lap to cool the rotors down so they don't crack when sitting stationary.
Hope to see you out there, make sure you come say hi and have a chat with us. We'll be based around the garages near the SAU Flags.
Yeah, I just fitted new qfm pads all round and good fluid a couple of weeks back, also added an oil cooler and bigger rad, so hopefully I've covered all bases. Thanks for the advice, I'll definitely come and have a chat. See you guys there:)
Good work
I can't stress it enough that even one day out can kill a car with no oil cooler / stock radiator
I'm currently paying for it lol
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
