My cams licence has expired any chance I can get a day licence for the day as funds are running low and just found out car needs a wheel bearing and an alignment before the track day
Hi Jason,
Come & Try CAMS Licences are only available to competitors who are new to motorsport and have never had a CAMS License before. So you'll need to renew your CAMS License in the standard way at http://www.cams.com.aubefore the event date. If possible do it asap, as it sometimes takes a few days to send out the new membership cards in the post.
So what are the entry requirements for the social sessions? Do we require a helmet, fire extinguisher, anything else?
Same as the timed sessions.
Clothing ankle to wrist, fire extinguisher in the car, helmet.
Im in, just entered. A lot of smooching has occurred of the past few weeks to get approval from the boss to attend. My car has been prepped and im eager to get out there, have some fun and see if I can match or beat my previous PB set in my S15. This will be the first proper test for my 33, hope she passes with flying colours. Looking forward to meeting some of the SAU crew.
  • Like 1
As 33's are a bit heavier and Sandown is a brake killer, make sure you have plenty of pad available for the day and remember that you can slow roll around the carpark out the back if you don't get a chance to do a proper cooldown lap to cool the rotors down so they don't crack when sitting stationary.
Hope to see you out there, make sure you come say hi and have a chat with us. We'll be based around the garages near the SAU Flags.
Yeah, I just fitted new qfm pads all round and good fluid a couple of weeks back, also added an oil cooler and bigger rad, so hopefully I've covered all bases. Thanks for the advice, I'll definitely come and have a chat. See you guys there:)
Good work
I can't stress it enough that even one day out can kill a car with no oil cooler / stock radiator
I'm currently paying for it lol
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
