Thank god Jack posted his Sandown time because I've been embarrassed being the #1 spot on that list given I can think of 8 GTR's faster than my time off the top of my head.
Sam
Benno
JFK
Aaron
Jack
Frank
Tony
Trevor
Scotsman
Roy,
I scrapped out a PB with the vic boys last Friday at EC.
1.48.48 but I know there were at least 3 vics who were quicker on the day, Im sure they will post up soon.
There was a 1.45 and 2 x 1.47's
Big john also broke into the 1.43's
Roy,
Well done Paul, to go 2 seconds quicker than previous is a top effort!!!!
Will send you some footage soon...
"PEEEEOOOOOWWWW" - the sound as you guys went oof topic :P
SAU Nickname: ZENNON
Car Make and Model: 92 R32 GTST
Circuit Name: Queensland Raceway Sprint Track
Lap time: 1:06.15
Modifications
Engine: RB20DET with FMIC, pod, gtr fuel pump and 3" zorts
Power: 160rwkw
Suspension: teins adjustable coilovers
Tyres: falkens wets
Brakes: stock rear, gtr front
Body weight: stock
"PEEEEOOOOOWWWW" - the sound as you guys went oof topic :)
Lap time: 1:06.15
Modifications
Power: 160rwkw
Tyres: falkens wets
Body weight: stock
Lap time: 1:04.26
Modifications since last track day:
2+ experience points :laugh:
(and not being in the n00b group helped too!)
Getting my r32 gtst 4door prep't up for the track, and looking at improving on my current times that i have recorded in a slower heavier car. However the 944 is amazingly stable and has more grip than a nuns you no what!
Porsche 944 S2
Weighing 1343kg with 148 kw at the fly (stock power and weight)
racing suspension setup , changing the rear tortion bar to a coil over setup
running
Bridgestone RE55 tyres
Pageant black brake pads
Calder: 1:09.323
Winton Long track: 1:40.021
Winton Short track: 1:09.142
Phillip Island: 1:54.645
Sandown: 1:29.356
Some more reference lap times for you Troy:
Bathurst - Richards/Skaife - 1.10.68
Sandown - Richards - 1.15.75
Mallala - Skaife - 1.10.68
Oran Park - Skaife - 1.10.26
Eastern Creek - Richards - 1.36.29
Winton - Skaife - 1.01.56
  • 2 months later...
SAU Nickname:zr240
Car Make and Model:datsun 240z
Circuit Name:Phillip Island
Lap time:1:47.6
Modifications
Engine: L28
Power:250hp (approx)
Suspension:coil over koni
Tyres:dunlop slick
Brakes:Mazda 4 spot frt and single spot rear
Body weight 950kg
Just brought a r33 turbo half cut to put in the 240z :P
Time is on natsoft from state round in about 2002
Ash
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
