SAU Nickname: Angus Smart
Car Make and Model: Skyline Gtr 32
Circuit Name: Eastern Creek
Lap time: 1:59:3
Modifications
Engine: n1 turbos pistons etc
Power: low boost only running 1 bar probably around 250kw?
Suspension: Aragosta
Tyres: re55s, ao48
Brakes: Brembo f50, standard rear
Body weight: around 1300
First time giving circuit racing a go! i'm hooked it was loads of fun! i really really really dont like turn two damn off camber make me slide
Edited by Angus Smart
Hahaha you damn mexicans!!!
I need to rock a better suspension setup. the local mr bob jane know it all is a tosser.
and get myself a tune! and a catch can.... oil everywhere after first Session
SAU Nickname: Liz
Car Make and Model: 180sx
Lap time: 2.03.37
Modifications
Engine: s14 sr20det
Power: under 140rwkw - car was dyno'd at 140 when the turbo was working. And pretty busted now.. so under that.
Suspension: Tein Monoflex
Tyres: kumhos (sp?)
Brakes: s15, rda slotted rotors front... bendix pads all round.
Body weight: around 1280 ???
I'll be happy when i'm under 2mins i think.
SAU Nickname: BHDave
Car Make and Model: 92 GTSt
Circuit Name: Wakefield
Lap time: 1:12.37 (natsoft)
Modifications
Engine: RB25DET
Power: ~260rwkw (was only running 1.2 bar)
Suspension: Cusco Comp 1s, 24mm f&r sway bars, lots of adjustable bushes and arms
Tyres: 215/45 17 AO48 front 235/45 17 RE55 rear
Brakes: R34GTt calipers with p mu rotors and pads
Body weight: stock minus back seat and spare
2nd time on a track, understeering pig all day combined with a ham fisted driver = not good
I think i have a bit of work ahead of me to make it onto the list. should be fun :)
SAU Nickname:Simonster
Car Make and Model:Nissan Sil80
Circuit Name:QR Sprint Ct
Lap time:58.7
Modifications
Engine:RB25 HKS3037S
Power:370rwhp
Suspension:HKS Hypermax2 7kg/5kg
Tyres:Dunlop Direzza F215/45/17 R235/45/17
Brakes: Nissan R32 braided lines RB74 pads
Body weight:~1300kg
SAU Nickname: Simonster
Circuit Name:QR Clubman
Lap time: 62.3
Hi Roy,
Please update my time to 58.3 for sprint track and 61.8 for clubman :(
Thanks gone softer on rear suspension as well!
Well im pumped to get back to the track now. I did a comfortable 1:38.2 on the weekend at Winton, whilst being held up by a F430 which i ended up overtakign around the outside. Only had two laps as part of the event...so cant wait to get back there now. Need to bang out a few good times whilst BBGTR is off the road and Ferni is waiting for his new wheels :) I am hoping to get to PI this weekend to give this new suspension a real work over. With any luck i will get into the 1:49s
Amazing, a mod that actually works sure does increase enthusiasm to get back out there :)
Need to ban out a few good times whilst BBGTR is off the road and Ferni is waiting for hsi new wheels :)
AAARRRGGGHHHH, the wait is killing me. Troy, was also looking forward to the MSCA day this weekend but alas it is not to be.
Just don't bin it going for a 220 kmh entry into turn one......
LOL...good point, but im more worried about the entry onto the straight. So keen to get back out there, I really dont know what to expect from the car. I seem to recall you have been punting around on the Bilsteins as well. I hope you like your new suspension as much as i like mine....its so much easier to drive now :).
SAU Nickname: Wogboy
Car Make and Model: 2000 R34 GT-T
Circuit Name: Symmons Plains
Lap time: 1:07.75
Modifications
Engine: RB25DET stock turbo
Power: 225rwkw
Suspension: SK Bilstien group buy
Tyres: Falken RT somethings 235/45/17
Brakes: stock
Body weight: stock
Gettin' there, Bendix Road Street & track pads only change from above. 1:06.43 26th Aug track day.
Had the fronts in for Winton, however it was all unbalanced with the old setup in the back.
mmmmmmm. Green goodness..... :)
SAU Nickname: 9krpm
Car Make and Model: R32GTR
Circuit Name: QR Sprint
Lap time: 58.1 (drift box)
Modifications
Engine: 2.6
Power:350+rwkw
Suspension: Bilstein
Tyres: 255/40/17 RE55R
Brakes: AP
Body weight: 1500 kg
Circuit Name: Mallalla
Lap time: 1:20 (AIM lap timer)
Anything change to pull a second out of your lap time...or was it just more seat time?
Better tyres (Dunlop D02 Semi's), bigger balls/stupidity under brakes.
I got down to a 1:01.64 today, I'll be interested to see what I can do when i have the diff repaired.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
