give or take a few years, you'll end up doing it LOL
more power, more torque, more response, more cheaper, less heat issues, less piping, less hoses to fail, less shuffle, less blown rear turbo
hahaha
  • Like 1
So I bit the bullet and had the motor removed to do all the heater hoses along with anything else that popped up.
Plenty more nasty little surprises but at least its getting sorted and will help me sleep better now.
Here's some progress pics.....all new genuine Nissan hoses.
So motors all back in now and running well.
While it was out I had the plenum painted wrinkle black to match everything else once I get round to it.
Have just had some new Hankook Rs-3 tyres fitted and I'm off to get a wheel alignment this arvo and that should be it ready for this weekends hillclimb.
Nothing feels better than KNOWING that everything is right. All the little things are taken care of. Then you can have the spirited drives with out that little niggle at the back of your mind.
Just a note if you already haven't replaced them are the two plastic connectors on the firewall. One at the back of the plenum which just connects two water hoses and the other behind the cam cover for the heater hose junction. They are prone to fall apart from the inside and flick plastic pieces into your coolant system. Well worth replacing if you haven't already.
  • Like 1
A few pics from the weekends hill climb (I believe it is the fastest speed hill climb in Australia)
I think I was the slowest in my class but I had a ball and managed to drive there and home so can't complain about that. (Unfortunately some weren't so lucky :()
Time for some more suspension work ready for the next one in August.
ye there's vids on youtube, search 'R32 GTR crash mt alma 2016'
Never like to see that happen obviously but this guy especially was a top bloke, was really cut up afterwards obviously.
Another GTR (32) and a few evo's had some pretty big offs too :-/
ye Glyn, I think it was a case of just too much speed, I chatted to him afterwards but didn't go into the details, doesn't look too fast but I believe he was somewhere around 170-180kph around there :-/
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
