My picks to suit various budgets - it is more important to change every 5000kms / 6mths whichever comes first, more so than a more expensive oil over a longer interval.
Under $30 - Gulf Western Syn-X 3000 10w 40 - solid performing semi-synthetic (refined mineral base) only published figure is the TBN of 9.02 (solid for 10,000km intervals) and good pour and flash points.
Over $40 - from light to heavy 40w oils - Shell Helix Ultra 5w40, Nulon Fast Flow 10W40 and Penrite HPR10 (10w50 extra 10 which is just a strengthened 40 weight) - all use a Group 3 refined mineral base, however they improve on the Gulf Western oil by meeting the synthetic standard of ACEA A3/B3, as well as many euro extended-interval standards such as Mercedes 229, and BMW ll-04.
Over $80 - my pick would be Redline's 10w 40 standard motor oil, which offers IMO the best combo of detergent for street, and high temp/sheer resistance for performance (HTHS of 4.4, compared to the Shell which has a rating of 3.68).
All these oils have a good combo of cleaning detergents / high-temp/sheer performance - IMO the difference in competency isn't alot over a 5,000km/6mth interval of street/spirited driving.
Factor in track time and extended change intervals, and the more you want to consider a higher priced oil like the Nulon, Penrite and Redline.
Edited by squareznboxez
  • Like 1
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699233
Penrite 10 tenths racing, Motul 300v or Mobil ultimate allround performance.
Those 3 oils are one of the best out there for turbo charged cars. Viscosity is obviously dependant upon engine mods, driving conditions and weather.
  • Like 1
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699334
Agreed these are out and out performance oils, however they are designed to be run on track at high temps with high sheer stability (which is good), and then changed after each event - the result is the detergent package in these hi-performance 'track oriented' oils is usually poor and not ideal for day-in-day-out start/stop accustomed to a street car
the 300V is now specifically a track-oriented oil, with very little detergency for 5,000km/6mth intervals
the Penrite 10 tenths isn't far behind however they should have some street manners - my pick is still the HPR10, but the 10 tenths does have a Group IV PAO basestock, where the HPR10 uses a Group 3 refined mineral base
  • Like 1
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699508
I did a little research based on what you said and 100% agree. Motul 300v is track oriented.
To the OP, i stand by the Mobil ultimate all round performance as its one of the best oils out there made for high performance cars. Its more expensive (around 100 dollars for 5litres) but its pretty damn good. To put it in perspective, i have been told a few guys have used this oil in their old ferrari's and its never skipped a beat.
HPR is also pretty decent. My mate is running penrite Everyday fully synthetic in his G6E turbo which is pushing 330rwkw.
You shouldnt really go wrong. Ive tried different oils in my evo ranging from castrol edge, motul 300v, penrite hpr, penrite racing, mobil ultimate all round etc.. and by far mobil was the best for daily driving.
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699770
You're on the money with Mobil 1, based on many UOAs (used oil analysis) in the US, this has proven to be a very, very competent street/track oil
Although they have changed to a refined mineral base but extremely competent additive pack making the overall product possibly better than the previous Group 4 basestock version
The RRP of $105 is a lot of money though, and i think there are better street oils out there like Redline, Amsoil and select Elf.
https://www.sau.com.au/forums/topic/463681-best-oil-to-run/#findComment-7699802
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
