Most people here would recommend the Quaife front diff over the nismo, as its a helical type diff instead of mechanical plates, helps with understeer under load. Also my diff guy doesn't like to install mechanical fronts as too much of the diff housing needs to be ground down to make them fit apparently
Additionally, note that for the gtx turbos, they aren't a bolt in affair, to get mine i needed to find a rear housing to suit and then get a front housing machined. As was mentioned in the first page, you should probably be able to get a turbo shop to do that using tx 2863's into your existing turbo housings. why not 2860's? because you cant machine something to be smaller than it already is.
You mean you'll get more lag and shift the mid range higher up the RPM..
Longer duration cams are not the answer to getting better response or making better mid range.. Yes you will make more torque yes you'll make more power but not where you want it.. and that's nice and early.
I have 272 by 10.8 cams on a 2.6 with -9 turbos and have full boost 21psi by 3800rpm on 98
put some smaller cams in you will get even better response.. and welcome back lol.. you went missing for a while
Check my build thread for very detailed Nismo install instructions including highlighted areas where to grind. It was not significant by any means.
Regarding the clutch diff vs helical...I think the nismo 1.5 instructions references that it is a lightly set clutch style...not crazy deceleration lockup (but I haven't driven mine yet). I'll let you know when I drive it.
I would also have chosen quaife but I would have had to become a dealer in the USA and buy 10 of them to get one!
Also nismo came with the bearings and seals. I don't think other ones do. (Tomei, quaife, etc).
Also don't forget you will be buying / ordering shims. The setup took a bit of time for me. I had to make 2 shims.
I understand there will be lag, but there is acceptable lag and a dyno graph that looks like a cliff face. Nothing and everything for a split second.
Dynos gives u info in one gear and WOT.
On the street you never load up 4th at 2000 rpm at WOT and wait for boost. Real world is different to a dyno.
  • Like 2
Also the EFR are literally the fastest responding turbos on the market right now. Geoff at full race made 704whp through the 8374 EFR on a stock bottom 2.6 with lots of headwork on E85 through a cat.
wow.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
