Yesterday I got the pressure sensor harness in and then started going through the stock ecu wiring and labelling everything I need to wire up to the new ecu. There wasn't a whole lot that I had to reuse. Ac in/out, powersteer, start position, and a couple of Digital Inputs and Aux outs Ive got running around the car. Was left over with a bunch of unused factory wires.
Went to run some speaker cable through to the doors but found out it's on a connector so that was a no go. Will probably end up tapping onto the stock wire and running to the back for an amp.
  • Like 1
I ended up drilling a hole in that door connector to pass some new speaker wire through. A large portion of the connector is blank, so it fit in there well and didn’t impact the other terminals/connectors. You don’t need to drill a hole in the female part in the door, as it’s not sealed and allows cable to be fed through.
looking good!
  • Like 1
8 hours ago, Duncan said:
Sorry if I'm missing something...does that mean you have to cut the speaker wires to remove the door?
It’s not ideal but you would need to disconnect terminals from speaker and feed through door as you take them off. I needed to add a cable anyway for my central locking solenoid for the alarm, so I re-purposed the old speaker cable for that and then the new wire was for the speakers
Got the speakers wired up in the doors today. I end up cutting the wire where I could access it and put new speaker wire on to run down to the crossovers and ran them to woofer and tweeter. I used the original speaker wire that went down to woofer to reuse the crimps.
Mate said he has a spot free to fab my intercooler pipes, dump and other bits and pieces on Monday so I started getting shit out and putting everything together that needs to go down with it. Got the rad in so he can fab the new top pipe to the hypertune hose as well.
  • Like 4
Got the old girl all prepped to be picked up for fab tomorrow morning. Finished bolting up the speakers and got the door cards back on and cleared out the loose bits and pieces from the interior.
Popped the cold side pipe back on and refitted catch can. Trimmed some more metal from the passenger guard so it will clear with the new position of the turbo.
Tried to push it out the front but my yards super muddy with all the rain we've had in Bris the last couple of days. Required a light tow to get her down the side, luckily from another Nissan 🤣 Got her into the garage and ready for the tow truck at 0630 tomorrow.
It's going in for dump pipe mod, screamer plumbed back with provision to vent or plumb like my first setup and also going to get the muffler moved back closer to the bumper which should make it look a lot better. Cooler pipes modded to suit DBW TB and new turbo, fab new top radiator pipe to mate with the new hypertune manifold hose and then weld up my shifter drop box.
  • Like 4
Got a message mid morning saying it was all done! Tow truck picked it up around lunch time and dropped it home.
I pulled it all apart and dropped it down to the powdercoaters. Should have it back next week sometime.
Popped down and grabbed some high temp paint and gave the radiator, TB and adapter a couple of coats. Came up looking sweet. It has a nice look to it.
Tomorrow I'll pull the dump and screamer off so I can wrap them with exhaust wrap. Then pull turbo and mani off so I can sand the mani back as its got a bit of rust coming through the ceramic coating and looks shit.
Edited by klutched
  • Like 6
Did a little bit this afternoon and pulled the dump and turbo off so I could take the mani off to clean it up and give it a few coats of paint. Wire wheeled what I could get to and then got the sand paper out to get the tight spots. Gave it one coat so far, will do another two tomorrow and see if I can fit it in the oven to bake it for an hour along with the adapter and dbw.
Hoping the exhaust wrap I ordered turns up soon so I can wrap the dump and screamer. Ordered 30M so I'll wrap back as far as I can to help a little with temp next to the box and also the floorpan.
  • Like 5
Did some baking today, managed to fit it all in the oven. Turned out pretty good. Hopefully it holds up well to a bit of tool abuse.
Popped a few pieces on to see what the colours will look like. Pretty happy with how it came up.
Now to wait for the rest of the stuff to rock up :D
  • Like 5
This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.
Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.
Once I do the second half I'll be able to final fit the turbo and exhaust up.
Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
  • Like 2
  • 3 weeks later...
Was away on holidays last week and hadn't heard from powder coater, so I gave them a bell and it was all ready. Went and picked it up yesterday and gave it a clean this afternoon and started bolting it up.
Mate finally got around to ordering my new ECU, hopefully thats here this week and I can start getting that mounted and finish the wiring on it.
Tomorrow I'll try and get the exhaust back in and see what else I can tick off the list
  • Like 6
Finished putting the rest of the dump on today. Itchy and a prick of a job with 5 vbands to line up with the plumb back setup but I got there in the end.
Couple of other little bits and pieces put on while I was at it. Need to sort all the wiring that has to come to the hot side of the bay so I can finish mounting up the boost control and emap lines.
Fingers crossed ECU rocks up early this week and I get some time to work on it.
  • Like 3
Finally got some time to work on it yesterday so I got cracking and made a bracket up to mount the ecu. It just fits in there with enough space to plug the harness in.
Got cracking on the rest of the harness and finished it up to realise I had forgotten a wire to power the DBW relay. So I'll be depinning it and running all spare wires through to another connector so they're easily accessible for future use.
  • Like 2
Wiring is finally nearing completion! Gotta feed the wideband and boost soli into the cab and pin it up inside then i can start on the incab i/o wiring which just needs to be crimped into a deutsch.
Tidy up and start putting the interior back together, get a new battery and plumb the surge tank back up then I can fill fluids and start testing all my I/O and can setup between the Link and TCU.
  • Like 3
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
