Not bad, much better than A1RM on the track but still gave up after 3 hard laps. Project Mu I would do about 5 laps before shit got hairy lol
Recently just bought Type D Intima pads, I'll tell you how they go after 30th May.
Wow 700C temp rating, higher than the A1RM. How do the SR go on the track?
My Intima SS's died on the hills, need some convincing to go back to Intima after that..
I have SRs. Great street pad. But I never use the brakes so I suppose I don't really test them!
How do the pads "give up" after track laps??
Sorry wasn't too clear, so what I mean say after 5 or so laps, the pads become ineffective at stopping the car also known as brake fade. Once everything cools down again by either doing a cool down lap or waiting for the next session then the brakes will be back to normal again until you've given them a pounding and they "give up" after x laps.
Brake fade is not the pads, that will be your brake fluid not able to handle the temp.
Fluid boiling is not brake fade. That's when the pedal goes to the floor and your lunch ends up in your pants.. Fade is where the pads exceed their working temperature and stop having a decent coefficient of friction.
That's pretty lucky then, because everyone else I personally know and race with all have used A1RM, all hate them, all have had brake fade, and half of them crumbled their pads.
I personally hate them, but I hate Bendix pads even more.
I agree, my A1RM's were shot after 3 laps or so of Phillip Island in the Stagea, but that is an 1800kg wagon with R34 Brembo's and 350kw.
Great pad for spirited road driving though, mine don't make any noise, and I have never had an issue on the road.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
