If you want ponnies. Its type b or nothing...type a would be a waste of money
not big enough over standard. Dont expect a huge power gain.
Lucky to do 10rwkw more up top.
Id put headstuds on the list before all that anyway. Otherwise your on
Borrowed time
260 ponnies lump nice if you want them tuned that way..can get a nice
rump/rump/rump outta them..if thats what you want..
cheers
darren
You will barely notice any lumpy idle with poncams
True
Borrowed time
cheers
darren
Planning on going type b anyway :)
Haven't heard/researched anything about needing to upgrade the headstuds though (not saying it wouldn't be important to)
Hopefully e85, atr45 roller bearing, type b Tomei poncams (might do rocker gaskets and timing belt while everythings off) and a solid tune gets me close to 400rwkw haha
Trying to decide on a wastegate as I know close to nothing about them..
http://www.turbosmart.com.au/product/ultra-gate38
http://www.turbosmart.com.au/product/pro-gate50
Edited by Swole
Hi bro, by the sounds of it im on same track as you. Ive got a massive amount of parts to put on over next few weeks then off to get a tune and will see from there anyway the parts i have to put on so far are: type b poncams, lowmount external gate manifold, atr45sat turbo with vband rear housing, turbosmart 38mm gate, turbosmart 1200fpr, 1000cc xspurt injectors, plasmaman plenum, t/b & bov, zeitronix e85 flex set up, haltech platinum pro pnp ecu, apexi avcr boost controller, apexi rsm, oil cooler and filter relocation, walbro intank big e85 pump, surge tank with big pro flow e85 pump, arp head studs, performance springs & titanium retainers, 1.3mm cometic head gasket and other cometic gaskets. And ive already got stuff like r34 gtr brembo brakes all round, big koyorad alloy radiator, extreme heavy sports clutch and lots of other gtr stuff. Will keep you informed how all turns out.. Cheers
50mm, the 38m too small.. your exhaust manifold pressure will be too high...
you'll need head studs if you want to get that turbo + motor to boogie
Interesting
That sounds awesome and very similar to my plans
Aiming for any specific figure?
Now I may also think about doing studs, springs, retainers and head gasket if I can save enough!
Yeah bro, if your taking the head off best off replacing head gasket with a cometic (steel) gasket. Better for boost. I was at around 290kw on 98 pump fuel beforehand. Im hoping for around 380-400 rwkw on e85. Also i just exchanged my wastegate from the 2 bolt 38mm ultragate to the 45mm vband hypergate for a better flow and a cleaner look. Will keep post informed and will put pics up to. Doing most work myself.
Yeh that's true
So far I've found the following, hoping these are the best prices:
http://www.golebysparts.com.au/parts/view/2063/55/nissan-rb20-25-26/camtech-camshafts-performance-valve-springs-lifters-adjustable-camshaft-gears/rb25-r34-performance-valve-springs-with-retainers
http://www.golebysparts.com.au/parts/view/251/54/nissan-rb20-25-26/gaskets-seals-and-head-bolts/rb25det-r34-neo-intake-gasket-set
http://www.kudosmotorsports.com/catalog/stud-head-2000-4301-4309-nissan-skyline-gts25-25gt-rb20det-rb25det-rb25det-p-489.html
http://www.kudosmotorsports.com/catalog/cometic-head-gasket-multi-layered-steel-13mm-nissan-skyline-gts25-gts25-25gt-25gt-25gt-rb25de-rb25det-p-1648.html
http://www.golebysparts.com.au/parts/view/54/23/nissan-rb20-25-26/timing-belts-timing-belt-kits-water-pumps-/rb20det-rb25det-rb26dett-gates-racing-timing-belt-kit
Same power figures I'm aiming for
Least you're saving a bit on labour!
Thats about the same i got. Dont get the intake gasket kit as for an xtra $20 get both intake gaskets in cometic. I reakon if you rang golebys they would probably do you a good deal. I got my head gasket and head studs for 550 then with springs and stuff good chance they will help ya. I was gunna buy new buckets and shims but can't find at all...
Can't find the cometic one, may not even bother doing it if I don't have to?
Yeh I may speak to them as I'm also getting the Plazmaman injectors, rails and reg kit from them
I know barely anything about wastegates, but after searching for a 50mm one I noticed they come in 7psi and 14psi:
http://gcg.com.au/turbo-parts/external-wastegates/turbosmart-external-wastegates/turbosmart-pro-gate-50mm-7psi-14psi-detail
Which would best suit my application?
Also just came across this:
http://www.ebay.com.au/itm/50mm-V-Band-Wastegate-Pro-Gate-ProGate-Blue-12-Month-Warranty/152098198351?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140117125611%26meid%3Dc481daac48094e95b3a6a29088c02b86%26pid%3D100009%26rk%3D1%26rkt%3D10%26sd%3D152098204562
Now obviously I'm trying to save where ever possible, so is there much difference in buying a Turbosmart rep one over a gen one? (besides saving $400)
Thanks
14psi spring will be good if your planning to run around 20psi boost. Turbosmart are very good gates and it probably is something u want to be of good quality. I have heard the cheap ones can leak. If you want to save money don't bother with the cams and head gasket for now. Just do the studs. Johnny dosepipe made 376rwkw the other day on a non neo rb25 ,stock hg, stock cams, stock manifolds. Neo should be capable of the same if not more.
Thanks
You want your wastegate spring as close as possible (or just under) your target boost so I imagine you will want more than 14 psi that is the one to go for.
From my experience, if you're running both ports on the EWG you're able to nearly get double the default wastegate pressure.. with older style (single port ones) you would try and load up the spring as close to your max. desired boost pressure to avoid boost bleeding off.
Cheers for the answers guys
Seems this is the best option for me:
If you want more than 14psi go for the 7psi 50mm, it comes with a 10psi spring in the box for 17psi
Might hold off on cams and put it into headstuds and gasket instead or save a lil more and go all out haha
ARP studs
Stock headgasket
Stock cams
Your favourite flavour of turbo
Genuine turbosmart gate
Plenty of power, safety and fun times guarenteed.
/thread
Heard if I change the headstuds then I gotta/may as well change the gasket too
Willing to chip out the few hundred for a cometic one for that added safety :)
Remember, 400's the goal now too! haha
taking off the head is more work, however if you're up for it then do it :)
However when you think of a budget build, then there's no "real" need.. just change 1x stud at a time and torque them about 20nm off their rated torque requirements, then go over them at the correct torque once all the studs have been replaced (from middle and work your way out).
  • Like 1
/\ I wouldn't open it if it doesn't need it, I'd prefer a Cosworth, GReddy or Tomei gasket
I could save so much if I didn't open it but I think it's worth the safety haha
Haven't heard anything bad about the 1.3mm cometic HG so think I'll stick with that one
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
