Got the turbo off without much trouble, i took lots of pics and wrote down the steps i took so i will probably post a diy for others once i finish.
I got the mamba braided line kit which included the turbo gaskets, nuts and studs. However the stock hardlines look fine and the waterline that goes from the top of the engine (just under rear of rocker covers) looks impossible to get to. I was thinking of just using the stock water lines or just swapping the easy waterhose with the braided one.
What is the benefit of braided lines if the stock ones are hardlines anyways?
Ok im tripping out right now. Started the car and took it for a short drive around the block to get it to operating temp, without hitting boost at all.
Now there is white steam like smoke coming from the turbo. Im hoping its just degreaser residue or coolant. None of the lines are leaking and i made sure to drip some oil into the turbo before starting the car.
Any ideas, im really hoping i havent stuffed this up :s
Looks like you're not using the stock boost controller. The line with the bolt in it looks like what used to be the bleed line. What sort of boost control are you using? I'll check back through the last 4  pages to see if you have mentioned it.
OK just read the whole thread and no mention. What are you using for boost control? i.e. what is connected to your actuator? Some kind of manual T ?
I was using a turbosmart boost t set to 10psi on the old turbo. the new wastegate actuator is 18psi but i had to leave the t on because i forgot to buy a vacuum line. Planning on getting an ebc though
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
