Got the turbo off without much trouble, i took lots of pics and wrote down the steps i took so i will probably post a diy for others once i finish.
I got the mamba braided line kit which included the turbo gaskets, nuts and studs. However the stock hardlines look fine and the waterline that goes from the top of the engine (just under rear of rocker covers) looks impossible to get to. I was thinking of just using the stock water lines or just swapping the easy waterhose with the braided one.
What is the benefit of braided lines if the stock ones are hardlines anyways?
Ok im tripping out right now. Started the car and took it for a short drive around the block to get it to operating temp, without hitting boost at all.
Now there is white steam like smoke coming from the turbo. Im hoping its just degreaser residue or coolant. None of the lines are leaking and i made sure to drip some oil into the turbo before starting the car.
Any ideas, im really hoping i havent stuffed this up :s
Looks like you're not using the stock boost controller. The line with the bolt in it looks like what used to be the bleed line. What sort of boost control are you using? I'll check back through the last 4  pages to see if you have mentioned it.
OK just read the whole thread and no mention. What are you using for boost control? i.e. what is connected to your actuator? Some kind of manual T ?
I was using a turbosmart boost t set to 10psi on the old turbo. the new wastegate actuator is 18psi but i had to leave the t on because i forgot to buy a vacuum line. Planning on getting an ebc though
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
