Heya :)
Im looking at buying a new pod filter for my R34 RB25DET Neo. Last owner had a DRiFT one in there.
I want to get the APEXi Power Intake pod filter but I've heard there's alot of fake ones out there on the market (ebay).
So I want to make sure that I'm buying the official one and not the fake one.
I saw some ones on ebay from china, philippines for like less than $40, so that to me sounds like fake.
There is this one on ebay for $84 from Aus:
http://www.ebay.com.au/itm/231873798273?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Does this one look legit? :huh:
https://www.sau.com.au/forums/topic/465856-fake-apexi-pod-filter/
1 hour ago, RosieR34 said:
I'd personally would never buy from Ebay for my car - why not spend $30 more and get one that you know is legitimate?
https://www.nengun.com/apexi/power-intake
Have you shopped for Apexi Power Intakes from this site before? Just want to make sure they are legit
I also saw this from Apexi USA:
http://www.apexi-usa.com/store/index.php/induction/power-intake/power-intake-kit/power-intake-kit-1989-1994-nissan-skyline-hcr32.html (will this fit on my R34?)
But the gasket in that pic looks just like the fake one that Dobz posted about. The shape of it :blink:
Im confused haha I just want to buy a legitimate one for the cheapest price :7_sweat_smile:
I used to have a geniune apexi pod, wasnt cheap. Eventually decided to buy another and it was fake. Does the same shit, literally next to no difference in quality. Had no issues making more power (after other mods). I now run a cheap n nasty pod that people have had solid results with.
19 hours ago, StaceyR34GTT said:
Heya :)
that one looks fake. This one is legit - blue gasket, and genuine seller, just cheap.
http://www.ebay.com.au/itm/APEXi-Dual-Funnel-Power-Intake-Replacement-Filter-85mm-UNIVERSAL-500-A021-/272279905575?hash=item3f6525a527:g:YA8AAOSwzJ5XZ6cq
10 hours ago, jmknights93 said:
Standard Apexi Pod to suit R34 GT-T RB25DET Neo
http://justjap.com/apexi-power-intake-kit-nissan-z32-300zx-22775.html
This looks promising! Surely JustJap won't sell phony stuff will they?
Also, one could just bolt the apexi pod filter straight onto the factory MAF (with the gasket ofcourse), right?
Edited by StaceyR34GTT
  • Like 1
  • 4 weeks later...
:UPDATE:
I got my Apexi Power Intake from Justjap today.
I compared it with this fake/genuine article:
http://www.zerotohundred.com/newforums/showthread.php?t=349923
Then compared it with this video:
Mine looks like the genuine one in the video. But the brass screw genuine design on that other article looks different to mine and the video's genuine intake. weird... and mine is 75mm ID :blink: ? Anyway check for your selfs
wait a minuite... wtf
PODs IMO would be one of the last things things to have major problems when using fake/cheap ones...
I'm currently running some $20 ebay POD in mine right now, I reused the gaskets from my Apexi one (and cleaned it with filter cleaner for use later on when this one gets dirty).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
