Hello!
I just recently had my Timing belt done and all the accesories, tensioners/pulleys etc. The shop who did the job is very reputable and have done many jobs like this before.
So when I got my car back I didn't notice anything, the car sounded fine. Drove it home, (3 hour journey) and just as im arriving when I do a pull from 1st gear in the parking space I hear a whinning noise from the engine? Was pretty tired so decided to look it up the next day. I read through some forum posts with people who experienced similar problems. That their belt would make squeaky noises, when warmed up mostly and around idle. In my case this is what i've discovered so far: Noise is there both when the engine is cold and warmed up and only seems to be apparent from 1000--1500rpm. Anyone have any ideas what this noise can be?!? More frustrating than anything!
The timing belt kit installed is a Blueprint oem replacement.
Video how it sounds: https://m.youtube.com/watch?v=OEsFwTc3Rp0
Edited by KLA33E
https://www.sau.com.au/forums/topic/466669-timing-belt-noise/
Unfortunately non OEM belts can be noisy.
My V-Spec II had a Gates belt on it and it was ridiculously loud,
Another GT-R I had had a very expensive competition belt on it and it was even worse!
Both were replaced with OEM and they were as quiet as a mouse.
You simply can't beat a genuine OEM Nissan belt from Nissan for noise.
Bob.
  • Like 3
I have a Gates racing belt on my 34R. Sounds very similar to the video you posted. As people have said, aftermarket (gates) are notoriously noisy.
My Gates has been on the car now for 20 Thou K's. No issues
(Update) We loosened everything up, starting with the easy stuff, servo, ac, and so. Noise was still there so we removed the timing belt. Then discovered that the tensioner pulley had residues of rubber on it from the belt probably? So the tensioner pulley was taken off and inspected for damage but seemed fine. Everything was removed and installed back together.
So my guess is the belt was put on a little bit too tight. The tension was doubled checked. Anyway the car is much quieter now, but I can still hear a small belt noise on idle but it goes away when the car warms up and introduces another sound (when warm) when you rev the car and it drops off at 1000rpm.
Overall I reckon the car is quieter now than before but not perfect. Guess i'll just have to drive it for a while and see if it goes away and if not, I may replace it with an Oem Nissan belt.
Edited by KLA33E
Same issue on my R33 S2
Timing belt done at 140ks, factory belt... Purred like a kitten before.
Approx week after getting it back it developed the exact same noise.
Was told that it maybe evident prior to even getting done and sure enough it turned up a week later.
As we all find out OEM just can't be beaten for it.
Pretty sure mine was a gates belt.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
