Hey everyone I've recently built in RB30 26 in my R34 series 2 I'm running Evan's waterless coolant new technology my car sits at around 95 degrees wondering if this is a standard temp in comparison to standard coolant additives.16e301d34ef80ed723f53bf3c1d76420.jpg
https://www.sau.com.au/forums/topic/466858-evens-waterless-coolant/
Never used evens waterless coolant but in theory shouldn't it run cooler? 95 degrees sounds hot for normal operating temp, my stockish rb25 sits around 82-83 operating temp with normal Nulon coolant and stock radiator.
though on the track my mates 25/30 sees 100+ regularly and nothing drastic has happened.
Just had a look through some of my logs.
Summer driving around without too much traffic sees anywhere from 70-85'C
Summer during stop start 80-92'C
Summer while setting up anti lag and launch control 85-93'C
Thermo fans, 42mm rad, Penrite coolant. Using the factory ecu temp sensor to adaptronic. Fmic. Fans turn on at 90'C and turn off at 86'C
I remember a mates NEO used to sit around 95'C during summer. The defi alarm would go off every now and then (100'C?). Stock rad, unknown coolant with a fmic.
How well calibrated is your coolant temp sensor @brodielezgt
That seems like a very low temp for std rad @dyl33
3 minutes ago, brodielezgt said:
When should I start getting worried.
I wouldn't be worried. Seems normal from what I've personally seen. And a quick skim through some old temp threads shows anywhere from 70'C-105'C to be normal. Obviously depending on your location and season.
Something to think about - With no fans and bonnet shut in the sun at idle, my temps seem to progressivly slow down once they get over 95'C. Takes roughly 10mins to get to 110'C
my mate ran this in his LS
temps improved 10-15C
but, he also had a leaking radiator repaired at the same time so i'm not sure if that had anything to do with the decrease in temps
not worth it i think. You wouldn't want a hose full of oil letting go on a high speed bend
plus, you have to completely remove all the water from your engine otherwise the product won't work properly (its best to use on a new engine that's never had water)
to completely dry out the water gallery's we removed the top and bottom radiator hose then connected a leaf blower into the top hose and let it blow into the engine for 10 minutes until there wasn't any more water coming out of the bottom hose
What did you  expect it to do? It is not designed to make your engine cooler it just has a higher boiling point than water...190 deg C if you believe the label. So water temp is not the concern - you should keep an eye on your oil temperature and pressure.
  • Like 1
Temps will be higher than water... for a perfectly working system.
Water has better heat capacty so will cool slightly better, until it boils. the point of this stuff is for bikes/crappy old cars etc where the cooling system is poor and you don't want it to boil even if it gets hot.
The racing coolant is the opposite, where you need maximum cooling (and also don't want to dump glycol on the track) and your cooling system is on point so its not going to get to a temp where it could boil.
Basically, best coolant is normal coolant.
  • Like 1
I ran this coolant in my RB26 after engine rebuild as heard promising results. Turned out to be quite expensive (compared to normal coolant) and as already said was really no different to normal coolant under normal driving conditions. I too expected it to run cooler but that is not what it's meant to do and just resists it more effectively. Didn't really get to test it properly under extreme conditions but had a few leaks and it smelt quite strange when spilt as well. When it leaks of course you must only top it up with more Evans coolant which is really quite difficult to find (had to buy mine through mail order) so if you are not carrying some with you and get a leak you are in allot of trouble... Ended up getting rid of it after not very long as it is just too expensive for not a great deal of benefit under normal driving conditions. More inconvenient to maintain for me and never had any problems with normal coolant anyway so just went back to that.
Im about to put in a new koyo radiator and during my research came across Red Line Water Wetter
The claims and reviews give it decent thumbs up, naturally I bought some as an option
Anyone able to vouch for it?
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
