'93 GTR Freshen up
Hey guys,
Long time lurker.
I'll try condensing the last 18 months into a relatively short post :-)
A friend of mine purchased this car from the east several years ago, I remember seeing it in the flesh and the colour just popped.
When it came up for sale, I jumped on it.
The lads at Galvsport were commissioned to the freshen which ended up being a ground up resto of sorts.
Premise was for a 1000hp street car with manners.  Engineered and insurable.   Carry out the school drop off and have a crack at some motorsport.
Posted Image
Posted Image
Posted Image
Stripped the shell and off for a freshen up of the BMW Boston Green.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
  • Like 5
https://www.sau.com.au/forums/topic/467143-93-gtr-freshen-up/
Posted Image
The shopping list as follows.
There will be a bunch of stuff I’ve missed, but you get the idea.
New RB26 Block @ 87mm
GALVSPORT specific block and head machining
HKS Step 2  2.8L
HKS Forged Pistons
HKS Forged Crank (balance, tested, sized and graded)
HKS H Beam Rods
Nismo engine bearings
ARP 2000 Main studs and nuts – Tunnel line bored and main bearings graded
New head comprising
HKS 272 Step 2 Camshafts
HKS Valve springs
HKS Bronze Valve guides
Genuine Nissan Valve stem seals
HKS Cam gears
JUN Cam baffles
Tomei oil restrictor
GALVSPORT head gasket
ARP 2000 head studs
HSE Billet oil pump gears
Modified GALVSPORT oil pump
GALVSPORT head drain
RIPS Extended sump
GALVSPORT extended oil pump pickup
Genuine Nissan  water pump
NSK Timing belt tensioners and idlers
HKS Super fine tune timing belt
Genuine Nissan cam, crank, rear main oil seals
GALVSPORT Billet oil drain flange.
GALVSPORT heater kit
HKS Exhaust manifold gaskets
HKS Intake gaskets.
Precision 6870 Turbocharger, T4 Split rear 0.84
GALVSPORT exhaust manifold
GALVSPORT dump pipe
GALVSPORT intercooler plumbing
GALVSPORT Power Steering reservoir
GALVSPORT Radiator Header tank
GALVSPORT hidden engine loom
GALVSPORT modified cam covers
GALVSPORT Oil/Air separator with scavenge pump to block feed
GALVSPORT Billet Boot plate
GALVSPORT Billet ABS mounts
GALVSPORT hidden brake lines, junction plates, brake lines
Turbo smart 60mm Power Gate
HKS fuel rail – anodized black
ID2000 Injectors with adaptors
R34 GTR Splitfire coils
Nismo Engine and gearbox mount kits
DCS Twin Plate clutch - 1000hp OSG Movement converter
R34 GTR Getrag 6 speed H Pattern gearbox GALVSPORT conversion
R34 GTR Front/Rear crownwheel pinion set, Modified tailshaft, modified half shafts
Radium Auto twin pump surge tank
Walboro 450 E85 pumps x2
Walboro 255 Lift pump
Koyo Radiator
BRIDE seat rails BNR32 left & right
Defi Adavnce BF Oil Temp
Defi Advance BF Water Temp
Defi Advance BF Exhaust Temp
Defi Advance BF Fuel Pressure
Defi Advance BF Oil Pressure
Defi Advance ZD Meter
Defi Advance Control Unit
Defi Advance BF Boost Amber
Defi Advance 80mm Tacho with Red Shift light
BRIDE Stradia 2 - Low Cushion *Carbon Aramid*
LOW MAX - Gradation *Black Logo*
Nardi Deep Corn 350mm *Red Stitch / Suede*
HKB Boss Kit
Glovebox relocated climate control unit
Custom Dash binnacle
Rays Nismo LMGT4 18x9.5 +12 Omori Edition
ANDRA/CAMS compliant bolt in roll cage
HKS Silent High Power Cat Back exhaust
Full Race ETS Pro 4WD controller
Hicas lockout bar
Link G4+ ECU
Honeywell sensor trigger kits
MAC 3 port boost solenoid
FLEX fuel sensor
Abflug Carbon Under Lip Diffuser
Top Secret Carbon Rear Diffuser
Karbonetic Carbon OEM rear wing (Boston green clear coat)
Carbon N1 boot lip (Boston green clear coat)
Garage Defend GT Carbon Cooling Panel
Fujiruma Rocket Dancer Carbon Flap Wing Blade
Varis Japan Carbon Bonnet (Boston green clear coat)
Cree LED H4 & H3 headlights
Zled tail light conversion
BC Racing ZR Coilovers – External Reservoir – F/10kg R/8kg
BC Racing adjustable front camber plates
Ikeya Formula upper control Arms
R35 Front and rear brembo calipers
AP Racing 396 J hook front discs
AP Racing J hook rears
Endless MX72 pads
Goodridge front and rear lines to suit
GALVSPORT billet dogbones front and rear
GALVSPORT billet hand brake bells
  • Like 6
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
