Ken's z31 I wanna go fast build
I am Ken from the Seattle area USA. I bought my 1985 300zx GLL non turbo 5 speed in 2011 with the impression it had blown head gaskets which only an RB  swap would remedy. I replaced the bad thermostat and drove it for 4 years.
Opportunities arose and I purchased a wrecked 87 300zx with what I assumed was a stock rb20 silver top and 5 speed swap for $800 usd. Car had been sitting for 6 years after the owner wrecked.
  • Like 1
Engine was siezed so I started to take it apart. What I found blew me away.
Internal:
.015" over custom Wiesco pistons
spool rods
full balanced rotating assembly oil snout to pressure plate
spec stage 3 6 puck sprung clutch and flywheel
acl bearings
hks step 1 cams 264/264
adjustable cam  gears and greddy timing belt
bolt on:
rc racing 750cc injectors
precission 5557e dual ball bearing with billet wheel
z32 maf
aeromotive fpr
Nistune type 2 board
The list of parts well exceeded my $800 paid for the siezed block.
I discovered the heard was ported by a hydroplane mechanic.
I have no idea as to what power the car made or what psi the tune was done at. All the info I have is the car ran for two weeks and then it was totaled.
Welded in a nipple for the iacc and Aacv as well as a flange for the synapse engineering synchronic bov.
Also a 3 core s13 radiator modded to fit and a custom made shroud for the 14" fan. Unsure on cfm but the shop who built the car for the previous owner had used an oem vgz31 radiator and shroud with this fan tucked inside very crudely. Lower coolant hose is fitted with a temp switch for the fan relay.
  • Like 1
Also when the previous owner of my 85 had taken the car in for diagnostic the brilliant mechanic decided to dump head gasket stop leak into the system and I did not want to chance the  heater core to fail and fill my fresh rb and radiator with stop leak.
My Z has modded knuckles, running s13 Lcas and tie rods with the rack moved forward 25mm to prevent over centering. Of course I have no pictures of my own parts. S13 coil overs front and rear and s14 tension rods. Welded diff and poly bushings but one day will have s13 subframe.
I will attempt to snag some photos in the day light.
Edited by Zrbsliding
 Share
    • He could just take the Bogan Cruise Ships setup... Already got a good setup, with blower, the auto was rebuilt too wasn't it? Perfect time for him to upgrade the tailshaft, diff, and axles...    And wouldn't need to waste money on redoing the Commos seats, as he could just buy race seats for the 5...   As a highly modded car he could avoid the ability to give it away to offspring too when they crash their cars...
    • It's really interesting how much it's moving left to right, and doesn't appear to be actually spreading. For this to be moving left to right, without flaring, means unequal forces being applied until equilibrium hits in one way or another.   Reasons it could be unequal; Piston sizes left to right are different sizes. Only minute differences. Pistons moving on different planes. That is, are they moving directly straight at each other, or slightly out of alignment. The fluid is restricted getting to one side.   Some tests you could do. Pull the bleeders on the left and right, fit each side with pressure gauges. It will allow you to make sure pressure is equal (and really, it should be as fluid flow is so damn low, so fluid flow dynamics shouldn't come into it).   With the calipers off the car, have both sides retracted as far as possible, measure very very accurately (think micrometre) distances between opposing pistons in four different spots per set of pistons. Firstly, on each opposing pistons pair, the measures on for different spots should be equal. If it's not, and especially if one spot appears to actually get closer compared to another, the pistons aren't aligned, and now the forces left to right won't be equal, as they're the forces fighting each other.   You can also pull all the pistons out, and very very accurately measure the diameter of them. If they're not equal left to ight in the pairings, and especially if the area of the pistons on one side is different to the area on the other overall, it'll all be out of whack.   My bet, is shit QC in making sure the pistons move in the same plane left vs right. Some minor out of square machining, and nothing will line up, things will want to move around.
    • Whilst putting a V8 in a MX5 would be fun, it would negate the whole cheap to run fun daily that the MX5 will be used for If I wanted a faster little convertible I would have got a engine check light, I mean a BMW Z4 M, but going off the issues that the guy at work who recently got one is having, it is lucky I didn't  Meh, horses for courses, the Bogan Cruise Ship is my go to for some horse torques
    • I reckon give him a few months, LSX swap would be good
    • Mark needs to get bored at work and order things on here...
