Picked up the short motor last weekend. I supplied the L24 front sump and oil pickup as the L28 has a rear facing sump and oil pickup so the block needed to be modified to suit.
I also had a clutch supplied with the motor as the flywheel face has been designed around the pressure plate and it’s balanced with flywheel. It's a a single plate unit consisting of a 2600lbs AP pressure plate with an Exedy organic race clutch plate, built by Jim Berry in QLD.
I've listed my Mikuni 44mm carbs and LD28 crank for sale and once they move I'll send the short motor back with the P90 head to be completed. I spoke with Jenvey about the 48mm heritage bodies and they wont be in production until March so I'll follow up then.
  • Like 3
  • 3 weeks later...
  • 1 month later...
Update time... The body is now booked in with Custom and Classic Cars for body work but probably wont be started until the end of this year due to the work they have on. I've seen quite a few projects they've worked on including another C110 and 240Z and the craftsmanship is outstanding so I'm confident the car is in good hands.
C110 -https://www.facebook.com/pg/CustomAndClassicCars/photos/?tab=album&album_id=522151214472678
240Z - https://www.facebook.com/pg/CustomAndClassicCars/photos/?tab=album&album_id=1328888837132241
I purchased the body kit from Restored which includes the over fenders, rear wing and chin spoiler and a few more missing rubber seals.
The other big purchase is the fully built P90 head to match my 3.3ltr short block. Turns out that Locky from LCR is taking a different direction with his 240Z (matching numbers L24) and offered me the head that was built to match. Specs are:
  • New 46mm Stainless Intake Valves.
  • New 35mm Stainless Exhaust Valves.
  • New Valve Guides.
  • Refaced Rockers.
  • High-side Steel Retainers.
  • HSD valve springs.
  • 54.5cc Chambers.
  • Manifold face has been drilled & tapped for an LCR external coolant rail - blanking plates included.
  • Injector notches have been welded up.
  • New Freeze Plug.
  • New Nissan Oil Gallery Plugs.
  • New Nissan Rocker Cover gasket.
  • New Kameari MLS Head Gasket.
  • Near-new Rear Collant outlet
  • Water Jet Blasted Head & Tappet Cover.
Ported by Les Collins at LCR Racing, Intake port flow (average): 228cfm @ 28" of H20 on a 90mm bore plate. This head flows enough to make 380hp at the flywheel so it should be a very strong motor for a little C110.
  • Like 4
  • 1 month later...
  • 11 months later...
So, I hope you're sitting down for this news... I'm dropping the car off for body work next weekend! It's finally happening. The shell will go on a trailer and I'll do a weekend road trip to SA. There will be lots of progress shots on body work and I'll be busy again with the car.
  • Like 3
I made the 1500km round trip from Melbourne to Mt Barker in South Australia over the weekend to drop the car off for body work. ETA on the job is approx 8-12 months but I should get some regular updates which I'll post. There is lots to do whilst I'm waiting, engine assembly, sourcing induction and ECU, gearbox, diff, suspension brakes etc. All of the running gear will need to be blasted and painted and there is lots of work to do on the final parts removed like the heater, aircon, steering column....
Getting a non rolling shell on a trailer is pretty tricky work!
We left super early for the 9 hour drive
The car looked a little sad sitting there but it's in very good hands
I dropped the GTR grill off for reassembly and painting and the GTR rear panel too as it's painted in acrylic at the moment.
On 27/04/2018 at 12:31 PM, Adzmax said:
lolol my favourite line
"Serious buyers only! I can’t stress this enough I know what these are worth. Don’t waist my time"
  • Like 1
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
