Just looking to see some feedback and opinions on changing from a stock intake to a forward facing style.
It seems like a fairly pricey thing to change and would take some labour and adjustments under the hood.
It seems very logical to run a forward facing plenum for many reasons. I would like to know what effect you felt it had on your car.
https://www.sau.com.au/forums/topic/467997-rb25det-forward-facing-plenum/
Look 100x better, 100000x easier to change/upgrade injectors, easier to change spark plugs... little bit of stuffing around to convert but nothing major. Much shorter inlet path.
Would be interesting to see if someone has done a back to back comparison on a near stock motor with no changes other then the intake... When I did it I changed injectors and turbo at the same time so cant really compare
I asked for back to back results on the same tune a few years ago. From memory someone did post results and they were in line with what everyone else says. The theory and results behind the plenum is almost the same as na, which is surprising.
Yeah they look good and you can clean up all wiring and coolant and fuel lines to fit below it. But it's still around $400 for a useless thing.
Have around $400 spare and want something to do? Go for it
I have talked myself out of non standard RB25 manifolds and plenum chambers so many times it isn't funny .
Just yesterday I was looking at a pretty blue Freddy going onto a GTS25T and asked again the shop owner does this cost torque and drivability right where cars are driven most of the time .  Quick answer , yep more top end but costs down low .
It is also very obvious that things like the thermostats housing and oil filter are considerably harder to get at . No crossover pipe but that's not real hard to remove once you've done it once or twice .
I think the reality is that the J pipe or whatever is the way to go or if being real stealthy you're stuck with return flow type intercoolers .
The factory alternatives are the RB26 setup or the Y pipe and plenum like some R34 RB20/25 DEs use .
I've got one on my motor,why? For bonnet clearance when my 25 was in my 180, now I still have it on my 32 as bonnet clearance with an rb30 and because top feed standard hight injectors.
More top end? Barly noticeable at 300kw, however there was a noticeable loss of low-end/midrange power on the rb25 can't comment on the difference with the 30 thou
  • Like 2
i have back to backs with 320rwkw greddy and plazmaman vs std and in both cases there was very little difference and there was zero difference between std throttle and q45 on the greddy at 350rwkw.
That said the extra accessibility was worth it on both cars as they see lots of track work.
  • Like 2
Groundhog day?
I've never regretted mine, but it was part payment for some wheels. Car has always driven fine
  • Like 1
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
