10 hours ago, Ben C34 said:
I Genuinely am disappointed that the head is going back onto that block........
yeah would be better as a table with a small plaque with the words "A Real RB Head"
What am I missing here? Is the block not clean enough or something?
Or are you suggesting 3L block with 3.4L stroker?
Edited by ActionDan
Not much excitings lately, been busy with house stuff and wedding planning however managed to clean up the block a little. Been contemplating throwing in forged pistons and rods however that's just opening up a new can of worms. The initial plan was to throw in a stocker motor but.... that didn't go to plan lol.
So being sensible I'm only installing new conrod bearings, spool crank collar, spool billet oil pump gears and then balance the crank. Just trying to contact a few machine shops but they seem to be so hard to get to. Might just rock up and drop it off.
Typical RB cranks, a whole 4mm to drive the oil pump LOL.
2 hours ago, R377 said:
With how much boost you run, i thought forged pistons would be a necessity
It's not boost that blows apart motors, it's torque :)
Also being a NEO motor she should be alright with a healthy amount of boost and power. Being a non-GTX style wheel now, I won't be screwing in silly amounts of boost like before.
  • Like 1
  • 3 weeks later...
Lek shu, have been super busy with other shit so le siet bok was put on the back burner. However look what turned up last night? :)
(My mate picked it up for me from HOR thus the not so good portrait photo)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
