Drove it tonight, gave it a bit of a squirt on the new motor. Does feel strong, but haven't given it a beating yet as it's still the 1st batch of oil.
Will dump out the oil then drive it harder this weekend :)
Not a bad turbo, comes on (gate pressure) about 4000rpm, from the trace you can see 0.8bar of boost by 3600rpm. Mind you this was all in 2nd gear. No 3rd gear squirts yet hehehehe
@Piggaz told you I was going to give it not pussy it around!!
  • Like 4
50 minutes ago, niZmO_Man said:
But does it dose?
not VL dose, but it is because running low boost and also has a stainless intake..will take the car and get some fab work soon ish :)
Haven't driven the car since but installed a modern head unit with bluetooth for hands free life :)
Some modern features for an prehistoric car.
2 hours ago, sneakey pete said:
If you can hear the radio you're not driving it fast enough...
That's what i tell myself anyway, need to get mine working again...
Haha its got some decent audio, Vifa splits and a DD ported sub. At the back there is a 4 channel and a monoblock to power the speakers lolol.
So late arvo yesterday, dropped the oil and put in fresh 15W50 Penrite Racing and decided to check the base timing. It was a whole 4 degrees off. Explains why the car had a bit of a boost creep running stock gate pressure.
Fixed that, then took it for a spin (in between that fixing the fuel table which didn't require much change from the old motor setup). Got the AFRs a bit leaner so now its hitting 11.7 and flat lining.
And yep, I raised the boost too haha.. Running it in at 1.2bar of boost with crap all flat timing it's baking shitty 245 section Dunlops. Took it to Mexico and wound out 1st 2nd and 3rd, think I'm starting to hate the car less. Followed by that ended up at my mate's shop in South Mexico followed by a session of donuts to bed in the motor further. Gave the keys to the other boys at for a spin too. One didn't mind the lag as the motor revved out to 8.3k the other said was a bit too laggy for his liking but nevertheless still put a smile on everyone's face.
Late last night thought I would try to download the footage from my dash cam, turns out the memory card is corrupted :(
  • Like 2
I'm running in this car a shitty Laser branded dash cam. It's the same as the G1W you see on OzBargain.
Also isn't the first time it has corrupted a memory card. Instructions clearly state only use memory cards in this list, clearly I'm not lol.. Have a SanDisk SD card in there it doesn't like.
I don't think it matters, I've got an older GoPro4 and a quality SanDisk card and it never seems to capture anything when I'm doing illegal stuff, it's really odd.
Ordered 2x 3.5" v bands, came next day.. Woo! (One pictured)
More exhaust mods, 3.5" into a 3" axle back isn't going to be optimal for 400kW+ worth of exhaust flow. Gotta open up that shit
  • Like 1
A bit of raw data from the car, we can see it's making boost within 200ms or so from gear changes. Not bad transient response :)
It's no EFR or GTX but for what it is it will make many GT-R owners with twins pretty sad lol
Haven't had the chance to give it a full belt and do logs because of the long weekend
  • Like 1
    • ..and forum.r31skylineclub has been down all week....anyone know why?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
