5 hours ago, Dose Pipe Sutututu said:
Subtle lol...
You used the word brilliant many times lololol
Wasn't me, but a close relation....
You'd be more interested in the car he replaced this with - an N55 335i AH3
Edited by GeeDog
On November 22nd 2018, I put an order for a GTX3576R Gen 2 supercore from Sparesbox.
Sparesbox then went all quiet for about 3 weeks, I then contacted them and they advise there will be a delay (thanks for telling me anything). Due to the lack of communication, they offered me a $35 voucher. Sure whatever, it's end of the year not like I'm going to work on my car anyhow lol
Fast forward a few weeks, Pxxx (trying to hide names) called me and she advised me GCG (their supplier) is unable to provide me the turbo bought, so the alternative was to bump me up to a GTX3582R Gen 2. A bit hesitant at first, I eventually agreed to go a tad bigger.
So, last week I received a package on Friday, excited I opened it and look what arrived ?‍♂️20190113_112207.thumb.jpg.06d94d86fd246bbb9bbc2a8723a2b1ce.jpg
So yeah, I got what I wanted nearly 2 months ago, but... I've ordered a 0.83 housing because I thought I was getting a GTX3582R Gen 2 not a GTX3576R Gen 2. If I was definitely getting a GTX3576R Gen 2, it would be a 1.01 housing not a baby 0.83.
So f you Sparesbox.
  • Like 1
Well... You said you wanted more response for skid pans. Maybe they heard you and this is they're way of helping you out.
When are skid vids of gtx3576 gen2 goodness scheduled?
So f you Sparesbox.
Moar raspanse, No Ragrats.
Keep the .83!
After Spool Imports decide to actually identify the gears I installed are theirs. The idiot sales guy said the gears I put in aren't Spool Import gears ?‍♂️
f**ken hell brah. This is why i don't want to let the Nissan out.
Sales guy needs a kick in the arse.
After Spool Imports decide to actually identify the gears I installed are theirs. The idiot sales guy said the gears I put in aren't Spool Import gears [emoji2357]
Sent from my A1601 using SAU Community mobile app
20 minutes ago, r32-25t said:
Was your reply, “then whose gears did you sell me?”
Nope, sent a photo of the gears from new.
No response today... sigh, should have bought a M4.
I waited almost 6 months for sparesbox to supply my EFR6758 and it was an absolute f**k around. I only paid $1900 for it. Ended up cancelling because they told me it would be a 9 month wait from that point (at the end of the 6 months). Cancelled the order and they refunded the money with no voucher or anything.
Purchased 6758 the next day for ~$2800
Sparesbox ring me the week later saying they just got their order in. I said ill take it still because it was so cheap. They don't agree to the $1900 that i was supposed to pay (was purchased during a sale) and want to charge me $3k
f**k sparesbox
f**k sparesbox
that's f**ked, and so obvious that they were doing everything they can to get out of honoring that sale price. I'd be reporting that shit to the ACCC
Guess I'm the odd man out.
I've only had good dealings with SparesBox.
However, I've only been buying basic service and repair items - with the exception of a billet girdle which they had a killer price on and shipped in good time.
ehhh my CBF factor is maximum. Was like 1.5 years ago now anyway.
49 minutes ago, ActionDan said:
Can they swap the rear housing for you?
Ordered it through someone else, worked out cheaper.
Trying to see if I can exchange
So.. some updates, returned the 0.83 for a credit note and will be using that towards a turbo drain, lines/fitting kit, etc.
Also ordered the 2nd revision of Spool Import gears, hopefully it doesn't need to come out again.
Lastly, come to an agreement with Sparesbox, they're doing their best to rectify the poor experience and making it up to be by shopping a rear housing at a reduced cost.
Guess that worked out ok, just in time for CNY.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
