13 hours ago, niZmO_Man said:
What company? That looks like lazy courier.
Couriers Please, turns out Sparesbox put the wrong address on the box.
I don't even know how that's even possible? The turbo got sent to thr correct address yet thr turbine goes somewhere else?
What the actual frak. Clearly Sparesbox is worse than Mwave
Geeeeee you're a lucky man, it's the world's first Variable Geography Turbo
  • Like 1
  • Haha 2
Got my manifold back from Hi Octane Racing, they powder coated it for $280. Not a bad price, but felt a bit ripped off when I dropped it off and they were like umm can't give you a price now but it will be about $200 to $300.. like a $100 spread? Anyhow $280 later I have a ceramic coated manifold lol.
Started to trim the studs on the head as advised by Sinco, turns out I only needed to trim only 1 not 2, mini win?
Looking the part now, because Shitbox/Spareshit/karntbox aka Sparesmoron sent my friggen turbine housing elsewhere I decided to test fit this turbo.
  • Like 4
3 hours ago, UWISSH! said:
Don’t hi-octane do this shit on a daily basis so they should know exactly how much a 6 cylinder manifold will cost
Yeah I know right? Oh wells, it is what it is but the coating is bloody good though so pretty happy about that.
Now to wait for the rear turbine housing to arrive (whenever that happens), then I'll mock up the lines with some left over bits and bobs  and put together shopping list and go to MSCN for a rape lol.
After that, off to the fabricators then hopefully some skids.
And update, Sparesbox only just realised the housing is just sitting at Couriers Please's depot instead of being returned to Sparesbox ?‍♂️?‍♂️?‍♂️
Is this a 3 Stooges episode?
11 hours ago, admS15 said:
ETA to activities in Mexico?
2 more weeks at work till my redundancy, then it's R33 time till it's done.
Aiming for the shitbox running in 3 to 4 weeks, will test skid then dyno.
  • Like 4
Popped on some studs and trying to determine how to clock the turbo to make sure the oil feed and oil drain clears the manifold.
Looks like I might have to go hard lines, oh wells lol.
  • Like 2
Called in "sick" then went to MSCN to get fittings, hard lines for the turbo setup.
Left wondering why I didn't go to work instead lol.20190320_131440.thumb.jpg.04468a53e276eab286919bba1ba799e4.jpg
  • Like 1
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
