13 hours ago, niZmO_Man said:
What company? That looks like lazy courier.
Couriers Please, turns out Sparesbox put the wrong address on the box.
I don't even know how that's even possible? The turbo got sent to thr correct address yet thr turbine goes somewhere else?
What the actual frak. Clearly Sparesbox is worse than Mwave
Geeeeee you're a lucky man, it's the world's first Variable Geography Turbo
  • Like 1
  • Haha 2
Got my manifold back from Hi Octane Racing, they powder coated it for $280. Not a bad price, but felt a bit ripped off when I dropped it off and they were like umm can't give you a price now but it will be about $200 to $300.. like a $100 spread? Anyhow $280 later I have a ceramic coated manifold lol.
Started to trim the studs on the head as advised by Sinco, turns out I only needed to trim only 1 not 2, mini win?
Looking the part now, because Shitbox/Spareshit/karntbox aka Sparesmoron sent my friggen turbine housing elsewhere I decided to test fit this turbo.
  • Like 4
3 hours ago, UWISSH! said:
Don’t hi-octane do this shit on a daily basis so they should know exactly how much a 6 cylinder manifold will cost
Yeah I know right? Oh wells, it is what it is but the coating is bloody good though so pretty happy about that.
Now to wait for the rear turbine housing to arrive (whenever that happens), then I'll mock up the lines with some left over bits and bobs  and put together shopping list and go to MSCN for a rape lol.
After that, off to the fabricators then hopefully some skids.
And update, Sparesbox only just realised the housing is just sitting at Couriers Please's depot instead of being returned to Sparesbox ?‍♂️?‍♂️?‍♂️
Is this a 3 Stooges episode?
11 hours ago, admS15 said:
ETA to activities in Mexico?
2 more weeks at work till my redundancy, then it's R33 time till it's done.
Aiming for the shitbox running in 3 to 4 weeks, will test skid then dyno.
  • Like 4
Popped on some studs and trying to determine how to clock the turbo to make sure the oil feed and oil drain clears the manifold.
Looks like I might have to go hard lines, oh wells lol.
  • Like 2
Called in "sick" then went to MSCN to get fittings, hard lines for the turbo setup.
Left wondering why I didn't go to work instead lol.20190320_131440.thumb.jpg.04468a53e276eab286919bba1ba799e4.jpg
  • Like 1
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
