13 hours ago, Dose Pipe Sutututu said:
Here's a shot just then, it's a bit dark.
I assume car won't dose as mad as it did with the Hypergear ATR45SAT 6+6 VL ulleh spec cast compressor, but fast is best.
Dose all comes down to the intake pipe.
Man I miss the way mine used to flutter.
Actually got told one day I really should remove the atmospheric BOV before another copper defects me for it... Full boost shifts used to sound like those stupid obnoxious atmo BOVs.
Low boost shifts, or just rolling on and off the throttle used to make some nice long slow flutters... Mmmmm flutter...
Yes and no :)
GTX compressor wheels (and similar) don't dose as well as 6+6 wheels.
Ever heard any car with a GTX wheel dose mad? Never lol
46 minutes ago, mlr said:
So when the tuner askes me what my goals are in relation to boost, my answer should be.....MAD DOSE....
Proper dose brings us together as people.
  • Like 4
Lek Shu baby, got some new Nissan coil packs and a new loom. As @WantGTR would say, it's "kinda cute".
And yeah, let's start it too lol
  • Like 1
Couldn't hear the dose?
Turbosmart 50mm single gate, should be plenty for this heap of shit car. Fitted up 4AN fittings and running teflon lines from the gate to the Turbosmart 4x port solenoid, all wired up to the Halalkebabtech.
Wish I never starting building this heap of shit and bought a BMW.
Anyhow, if anyone needs Turbosmart products, you know who to ask. I can get anything from their range at a competitive price :)
  • Like 1
Look at the neat tool lay out.
My tools live in a couple of boxes which get tipped out to find stuff.
I keep thinking about what car I want next, I don't have a clue though, it does need to go around corners well, and be RWD, and manual......I'm a idiot.......
Get a brz ?
I get angry and yell at tools if I can't find them lol, hence they're all laid out nicely lolol.
BMW m235i :)
1 hour ago, Dose Pipe Sutututu said:
BMW m235i
Oh, that looks good.
I am scared of the reliability factor, BMW's were rubbish when I was growing up, poor after sales and blindingly expensive for parts and to service.
I was told if I really wanted one to buy it new and then sell it before the warranty ran out.
Have things changed?
  • Like 2
Nope
in fact talking to someone who works at a bmw dealership every time one comes in for service they can send it out with an essay of repairs that are required
    • I tried the next one up from 600k ohms which is 60M on my multimeter and all readings came out as 0.00 ohms so right now the most accurate is 600k ohms with only a 0.1 ohms difference between coils. Three coils read 1.4 ohms and the other three read 1.5 ohms.
    • surely that is a control arm, not a sway bar. In any case, visual condition should not be an issue, excessive movement under load (eg with a big pry bar) would be the issue. I can't see 99.999% of pink slip places even looking, let alone trying to test it
    • I attached the image of the only thing I found, nothing to do with ohms in the manual only torque values etc. However, being they are so close to each other I am almost certain they are good. Tomorrow I will test the spark plugs while I am there. and look at the ECU connections.
    • Hi Gents. Do u know what 18rim will fit under R32 GTST with no modification of current setup I have. I have buddy Club P1 17x8 on front and 17x9 rears and they fit well.   Will an 18x9 on 35 off set with 235 tyres up front fit? ON the Rears i can run the rim size n fit 255 or 245? or i got option to get 18x9.5 on 35+ Offset n 265?   CHeers
    • And, when measuring and getting <2 ohms, perhaps chose the next larger range than that, rather than something with a k in it!
