4 hours ago, niZmO_Man said:
Nice whiskey! How does it taste? I never tried Australia, $70 Aldi whiskeys for me
tastes a bit similar to a Hibiki 12 to be honest :)
However, it's hard to beat the Aldi 8 Year old Highland Black. I poured some out to my whisky snob mates and ask them to rate it.
Then I told them what it was and price and they were all mind blown.
On 5/14/2019 at 10:19 AM, ActionDan said:
Only 3yrs? pathetic.
8kg washer for 2 people?
Is this your way of telling us you're expecting twins?
I have a 10KG washer for 2 adults.
Never wanting children.
Have dog and 2 cats instead.
Is freaking awesome when you see the blankets we throw in it :)
also can save a month's worth of washing and do it in one hit :P
  • Haha 2
Update, started to assemble the cabinets. Looking pretty good. Glab the measurements turned out right and I didn't cook it up.
Just need a bigger hole saw to cut the drain pipe into the cabinet and relocate the power again. Initially was going for 3x 400mm cabinets but ended up with this arrangement instead.
Once the cabinets are secure, then I'll get the stone guy/girl to come fit it in, followed by more tiling then fit the top cabinets and I'm done!
I wish I had this kind of motivation with the car lol.
  • Like 1
7 minutes ago, ActionDan said:
Fair enough, whatever makes it more enjoyable for you.
I like flames but...
Dw, it will still launch flames :)
Remember the gate is plumbed back after the cat
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
