Nek level steering wheel lock, saw this in Naples, Italy. Gosh what a shit hole lol... I suggest for anyone considering on visiting not to stay there, if you're going to the beautiful islands just go direct, don't waste your time in Naples (however the pizzas are so cheap it makes no sense, a double scoop of gelato cost more).
I'm back in Australia, didn't get deported or stopped at boarder security!
Needed high heat for this dish and the induction stove top just won't cut it. Used a butane camping stove (with the holes drilled out), and I'm sure now the R33 is covered in oil splatter but at least it smells good.
  • Haha 1
Prev owner was into Auto Salon, hence the car is purple and he used a hammer to roll the guards (the car had wanky 19s on it) he didn't reseal the cracked paint and rust took over. Then when I needed to fit the 18x9.5 +22 with 255 wide semis, I went to town with a guard roller and destroyed both guards.
Also going to reshell next year so don't care :)
Hasn't moved in 2 months, just gets started, rev it a few times. Once it's warm, I commence a few anti-lag hits to spool the turbo and it gets turned off.
  • Like 1
Did one ages before but on shitty tyres, I fear trying in such a small space with semis might propel the car into the Tiguan lol
  • Like 2
  • Haha 3
Rest it up against the tiguan. Then skid.
  • Haha 1
PowerFC delete, Nistune install, upgrade to Z32 street tuna. Ready for dyno in a few weeks, runs an Auto Salon special Garrett GT2871 from the 90s and Tomei Procams.
Owner wants it on 98RON only, should see 230kW to 240kW on crap all timing to preserve the motor.
  • Like 3
Who's keen on buying the car as-is? I cbf, I can tune it before it goes too if the price is right.
OR is anyone keen on the car minus the motor, electronics (ecu, wiring, sensors) and fuel system? I'll leave the rest in (MCAs, KAAZ diff, all the suspension shit,  Bride seat, hectic ulleh stereo.
Clearly over it.
Straight up swap for a 335i F30 M-Sport with under 70k kms.
Getting that modern VW has changed me man, I didn't think it would affect me that much but it has.
The sheer lowdown torque, ridiculous gear shift speeds and luxuries has changed me for good.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
