Buying a new car isn't the be all and end all you think it is.
I still battle daily/weekly with buying another S14 for skids even though I have a perfectly capable albeit expensive skid car (f80 m3).
3 cars is probably already enough I don't need a 4th really....
That's true, however the creature comforts and all the tech aids in new cars make driving just so much more fun. Want smoke? press a button, want crackles? press a button, want firmer suspension? press a button.
Let's see, maybe once I hit up Wakefield again and chop a few GT-Rs I might be happy again.
Yeah but you just don't feel as engaged with the car.
Something that is a nice daily that you can take to the track is still going to be compromised.
Unless you are daily driving the 33 I don't see the point in changing it out.
1 hour ago, niZmO_Man said:
Depends on your definition of fun. Pressing a paddle and hearing farting noises vs. shifting gears yourself.
Yaasss!
This lol.
I must say, I didn't like the whole paddle shifter thing, but it grows on you. Press paddle and concentrate on next corner, it can be quite fun. Almost feels like you're driving the old Super Tourers with the sequential paddle boxes.
Yer I find I only ever use the paddles on down shifts for braking, very rarely on acceleration.
Generally off the lights its just gas it lol
But if I was going for a run up Macquarie pass or something like that, Ill use the paddles
Oh an only ever when the wife isn't in the car lol
  • Like 1
Was windy last week and my GTR boot and spoiler hit the pavement pretty hard and door toppled over onto the car.
A week later they're both in the same position lol.
  • Confused 1
  • Sad 1
A year later, decided to get off my arse and update the engine number, also the 1st time I've driven it in 3 or more weeks.
It's not slow aye? Got it a bit sideways then I stopped and thought, I really need to keep my license for work so gave it a few more hits now it's back in the backyard.
ummm.. not sure, it's covered in dents/rust - puts me off and I need to throw the Nissan idle control valve in the bin, and also the throttle body and go DBW.. The idle control reacts so slow and stalls sometimes with the AC on, I suspect it's filled with gunk and crap from 20 years of terrible air filters and engine blow by.
But that's money I don't want to spend and time I don't have to setup the DBW lol... so it stays how it is.
f**k the a.c. off, open a window.
#streetcar
  • Haha 1
#streetcar
Yeah it's Nissan, power window reg died on the LHS.. piece of shit doesn't go down
Rotated the wheels on the beast, man 20s aren't light. They're like 25kg per corner!
Dealer wanted to charge me $40+ for a wheel rotation during the $420 service, yeah nah.
Also, wheel bolts are torqued to 140nm not 100 ~ 110nm like wheel nuts.
Yes those are OEM lock bolts :)
20190922_100314.thumb.jpg.689ed2744f1f570e65e111ecc4130758.jpg20190922_103945.thumb.jpg.338eb33a666b0835145e487444bb2ecc.jpg
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
