On 11/14/2019 at 11:48 AM, robbo_rb180 said:
add in a manifold and external gate adds more $$$$. Been in the wrx from the g series thread and it is great but the cost to do it I think out weighs what the average person needs. For myself it was an extra $1600-1800 to go G series (vband housing, manifold & gate) over the gen2 gtx and I am happy with what I have done. If/when they do a T3 housing for G30 that will be when I jump on that band wagon.
Back on topic, so when you appearing on The Block?
Who knows how long it'll be but it's coming...
4 hours ago, Bond said:
So has it been on the dyno yet?
My own car? Nah been lazy. No incentive to get it on the dyno. House renos have taken priority lol.
I'm thinking of taking the motor out and putting in a Nitto oil pump, checking the bearings (sounds a bit "knocky" lately), and fitting a better balancer but that's effort.
19 minutes ago, GTofuS-T said:
oof...already? after all of... how few kms and no track time? ?
I did mince up the first set of Spool oil pump gears then replaced it with a new N1 pump and new Spool v2 gears. Then also noticed at high RPM (stationary) the power steering belt wobbles quite a bit, which shows signs of harmonics.
Sigh ?
Should have just popped in the stock NEO motor with a fresh HG, ARP studs and called it a day not get carried away and build the motor.
  • Like 1
Drop the sump and check the bearings. Dont drive it til you do. Do the oil pump while it's apart, don't f**k around and risk $$ on the motor.
You had it balanced right?
Yeah last time the oil pump went funny, I dropped the sump with the motor strapped up in place, no metal shavings and inspected 1x rod bearing and looked fine.
Crank was balanced, however I am starting to think it could the A/C idler too as there's a bit of play.
Yeah can check, but it's not an easy task!
Just now, ActionDan said:
Bathroom looks great, I'm sure that shower will get your wife wet.
LOL you dirty white man
This week only, $240 for full set of Intima SR brake pads OR $250 for Elig Sports brake pads shipped with Invoice for Sumitomo caipers, i.e. Benshit DB1170 and DB1220.
Happily knock off $30 if you bank transfer (still get invoice, ShitPal takes a massive percentage for payment - so try and avoid)
  • Like 1
mmmm, the sil80 will need new pads and rotors after Fridays looming trackday ?
Haha PM me, I'll look after you :)
I really should blog about my tuning aye? one of my mates gave me that idea - since I kind of already do it here on SAU but it just gets lost in the boat talk - have a read!
https://www.nhbautomotive.com.au/blogs/news/tuning-a-nissan-200sx-s15-on-e85-flex-tune
Also use the code NEARLYSUMMER for 15% off ALL BRAKE PADS :)
  • Like 1
3 minutes ago, ActionDan said:
You want me to follow a link where the end result is I cannot shit talk like I do here?!
there's a comments section - you could talk boats there too LOL
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
