On 22/02/2022 at 4:04 PM, niZmO_Man said:
yeah try finding parts for a GT-R
anything on EFI Solution site? I can help you with that.
BTW... I might have been told Haltech Elite will be supporting canbus keypads and they have a test version working on the bench. I may or may not have heard that :)
@r32-25t unwire all your old school switches eating up your AVIs, time to get a canbus keypad :D
keypad - Haltech
  • Like 2
keypad - Haltech
I don’t have any switches on the AVIs, I’ve used them all on sensors and need a few more
Remember to use your old afm inputs if you haven't already - there is another 2 AVIs doing nothing otherwise.
  • Like 1
haha, already went there, even used the 2x narrow band inputs too.. I went to town.
No more spare inputs :D
Ive grabbed them and the original O2 sensors
  • Like 1
Same. Don't have Emap but have Exhaust temp.
  • Like 1
On 22/02/2022 at 5:08 PM, r32-25t said:
thats my list and to that I’d still like to add fuel temp and maybe a trim switch which jem have managed to make work with the eboost2
You have flex sensor on an spi yes ? Fuel temp is incorporated into that - no avi required.
  • Like 1
Depends on sensor too, some seem to not send back fuel temp however all the new smaller/compact Continental ones I've setup seem to.
Yeah it’s on that but it’s an older one and I’m not sure if it does temp
Might need to switch it then. From what I've seen the Haltech, VDO, Continental, AC delco and GM ones with the 3 mounting holes measure fuel temp - they all seem to be the same thing if it looks like this. I have a genuine Haltech one on the blue 32 and the white 32 has a VDO one with shorter pipes but same body;
If it is like this below I'm not sure - probably doesn't but I have no experience with them to confirm:
keypad - Haltech
Bit late to the party mate with that.
Haltech have been really adding heaps of stuff lately with this NSP update.
Still waiting on the Mexico trip video........
  • Haha 1
I’ve got the haltech one with the 3 bolt holes so I guess it does it, one less AVI that I need now
  • Like 1
just be sure to select this when configuring the input
And if you really want your fuelling to be spot on, make sure you build out your fuel density table. Most tuners don't bother with this and just rely on the static value density that is default on the Haltech. You really need density vs. fuel temperature to have accurate fuelling. Car idles so much better now with this table defined, also with DBW sure makes A/C, big cams and idle a walk in the park.
  • Like 1
Adam at JEM setup my trim switch to the eBoost settings and also to boost by gear as it’s auto. It works really well
  • Like 1
I saw a video of it and he was talking to me about it when I was there about 6 months ago. If I decide to put an expansion box on it I’ll get it all set up
Forget about the eBoost, 4 port solenoid and canbus keypad.
Have buttons called 400kW, 500kW, 600kW, Rolling A/L, Launch Control, etc.
:D
:D
Mines a dad wagon. I need better names. Wife, Kids, No Kids, Noisy Button etc
  • Haha 3
So this should work
  • Haha 2
Walked in, walked out $550 poorer.
I now have new bonnet/hood insulation 😂
Amayama couldn't source one, Kudos couldn't either, even tried EFI Solutions but somehow Skyline Spares could so yeah, sent it and bought it.
This is more expensive than a coacine addiction.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
