On 21/08/2022 at 9:54 AM, Dose Pipe Sutututu said:
There are plans for it, been a plan for a while lol.
I really should just do it, mainly for safety. Especially now I'll be easily doing 220 to 230km/h down the mainstraight at Wakefield Park (provided it even stays open now due to all the issues they're having).
https://autoaction.com.au/2022/08/19/wakefield-park-to-shut-the-gates-september-1st
  • Sad 3
On 22/08/2022 at 7:57 AM, admS15 said:
Here's hoping it's shut for a month or two and there's massive economic backlash everyone begs for it to reopen asap.
If not, there will be plenty of cheap houses, cheap commercial properties for sale very soon.
Let's be honest, there's not much to do in Goulburn
I'm still shocked it got this far.
Have been chatting with John Boston about (Track School) who's business is now basically on hold until something is done.
Yeah it sux big time.
I have done a few Trackschool days and they are awesome. Run very well.
Sad day for sure. Hope it does reopen, but I have heard rumours through a friend of a friend about a land development in the area. Hidden agendas etc.
I also hear from the same person that Pheasant Wood is planning on expanding its track to something like 3.6kms,with 2 big straights, which would make it bigger than Wakefield.
may also find a few cheap race car and trailer packages on the market if it stays shut
  • Like 1
  • Sad 1
It’s zoned residential so probably no industrial buildings
I was referring to the pubs/cafes/shop fronts etc. commercial properties up for sale soon when all the tenants vacant and landlords are forced to sell as they can't keep them.
I hope Wakefield doesn't shut.
  • Like 1
On 20/8/2022 at 5:25 PM, Dose Pipe Sutututu said:
BBQs Galore
Yeah I want to get a side exit extension for the screamer so I can roast marshmallows during antilag comps 😆. The yanks would lose their mind
  • Haha 1
2 Step Comp dis dat... funny it's not even "2-step", it's actually anti-lag with a secondary RPM limiter but hey it's cooler to just say "2-step".
Muricaaaaaaaaaaaaa fk yeah.
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
