19 hours ago, Dose Pipe Sutututu said:
Just measured it, it's 134mm. OEM requirements is about 143mm.
Looks like might need the Dayco 115847 instead.
Fuarking.
well, FWIW that is the size that the GKtech adapter is designed for (134-143). I was going to say I have one for half price but looks like they are on sale for $19 atm anyway.
However, taking into account the feedback above on aftermarket couplings (I've got no experience with them, but surprised if they don't work out of the box) and I saw something about the Dayco coupling fouling on the GKTech adapter...it might be best just to go OEM
After all, we know you are keeping this car for 20 years and continuing to say how you want to sell it and buy the new BMW electric hover m2 instead.
  • Like 1
Thanks for the thought anyhow Duncan!
I will just return the fan clutch, I've already messaged the seller on eBay however no response.
Might just give it till about Tuesday and do an eBay return, then cry a little and order a brand new OEM unit.
3 hours ago, Piggaz said:
Sitting in the garage. More than welcome to see if it fits, was working fine only removed to suit dry sump setup.
Might take you up on the offer on the fan hub fits.
Will do Google tonight, intensely lol.
If not 2x options, both equally costly.
1. New OEM hub
2. FFG shroud and 16" Spal fan.
5 hours ago, BK said:
Don't think so, part is 21U082-05U00 and they're f**king $800+ now !
It's "nearly" the same 21082-75T02
Wonder what the real difference is
1. New OEM hub
Come get it and have a play. If it fits, great, if not return it or sell it for me. 🤣
Any chance you can measure the overall height from the hub to the top side of the fan?
I feel that they're nearly the same, perhaps different height (GT-R being probably shorter than the GTS-t one, however I'm running essentially a Koyo radiator for a GT-R).
50 minutes ago, Piggaz said:
Hmm mean from the top side of the fan blade to the base of the clutch, ie if you sat the fan flat on a surface, how high would be be overall.
100mm overall
95 for the height of the blades
I'll grab it, just measured mine and seems about the same height 98mm or so.
Considering the fan blade is identical and the water pump on either motor are the same it should be good.
I'm going to assume you want to get rid of the clutch and fan blade together?
3 minutes ago, admS15 said:
I'm happy to purchase a fan blade if there's one surplus. Mine has started to get little stress cracks and could do with replacement. Just saying😉
Sounds like we a threesome in a non homosexual way.
  • Haha 1
Yeah clutch and fan together. Fan blades would be lucky to be 5000 kms old.
PM me your number bro, you can't receive PMs for some reason lol.
Thanks again @Piggaz, shit box now has a working fan clutch/hub/coupler
Weirdly enough the RB25 one is higher than the RB25, so this means the fan blade is now even closer to the radiator shroud!
I have a out 6mm before the blades kiss the top flat part of the shroud. Might trim off that flat part if it causes any issues.
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
