You would have thought nissan would have just used the same hub on everything.
Why didn't you down grade to a ling long dual 12inch elec fan setup 😂
  • Like 1
Because I'm not an idiot 😂😂😂
Not to mention the car actually gets driven on a track not around the local Bunnings carpark and 10 to 12s at a time and left to cool down for an hour between "races".
  • Like 1
  • Haha 3
Technically at the the racetrack the fan should be off given how much air is flowing through the front of the car but like yeaaaaaaa.
Yeah I suppose, however here's food for thought.
Most of the Nissan shitboxes I've seen at Wakefield all run factory fan setups. I've actually never seen anyone at Wakefield with two thermos or similar on a RB powered car, I have seen a few Silvias with Falcon twin thermo fans though.
I have run twin fans for years now, drag race track race and street drive and have never had a problem with it ever. Car sees street use and might hit 82 and night drives sits around 76.
Dont know why people bang on them. They’re perfect and easy to control.
Hottest car gets is doing a staging burn out that can go for 20secs and it will hit 92 and then after the run it’s back to 82.
I’ll take a video of it tonight to prove my point that’s it’s better than stock
Because 90% of the installs are done with crappy fans with rubbish/low CFM, wired incorrectly or not using shrouds. Go onto those R33 Facebook groups and you just see people installing Ling Long special fans straight onto their radiators using those fan zip ties or using those flat sheet shrouds without spacing the fan off the radiator.
Rarely do I see anyone do them correctly, closest I've seen was a S13 using a factory Ford Falcon fans however he had a Davies Craig fan controller which to be was a let down. Should have used his ECU to trigger it with hysteresis so they don't turn off and on like a mad man.
I know they work, and work well, when the implementation is well thought out. Just with most R33 owners (not you or the other R33 owners on this forum) they seem to do things that are terrible.
  • Like 1
Also depends on climate.
I have lived where its 36-38c and 75+% humidity and car would run at around 84-86 cruising to now 10-30+C 40-55% humidity car runs at 72-76 up the highway and around 82c cruising suburbs.
Not 1 change to the cooling system. 40mm rad, header tank, ducting and a 14 push and 12 inch pull fans, 1 set to 87C and other at 90C.
  • Like 2
2 hours ago, WR33KD said:
So this was town driving with stop starts hitting 50kphFD4BC68C-59ED-4CB2-B356-221ABC0DC416.thumb.jpeg.23a7050deccab8dfbbb549e5d139909a.jpeg
did get to 82 at the lights when stopped
and this is open road driving doing 100-110
That's good, a rare twin thermo setup that works!
What fans are you using?
53 minutes ago, Dose Pipe Sutututu said:
I swear this place consumes as much money as efisolution and kudos does lol.
I’ve got a wagu brisket in the smoker at the moment
  • Like 1
Yummy, I haven't used my smoker in years since becoming a dad.
Now it's hot and fast or pressure cooker then sear in the gozney
I use mine fairly often but I have a pellet on where it basically keep temperature on it’s own and I can work on the car or what ever I need to do
  • Like 1
That's what I might move to one day too, the kamado is great however requires constant manning.
I'll pick your brains when the time comes
Merry Christmas my retarded Skyline brother lol.
  • Like 1
That’s a great way to get car time. “I can’t come inside I’m cooking. “
I’m “cooking” the Turkey at the moment 😆
  • Haha 3
No worries trust me they make life to easy
Merry Christmas to you to mate
On 18/12/2022 at 9:46 PM, Dose Pipe Sutututu said:
Might take you up on the offer on the fan hub fits.
Will do Google tonight, intensely lol.
If not 2x options, both equally costly.
1. New OEM hub
2. FFG shroud and 16" Spal fan.
I have ordered the FPG fan shroud, so can provide a direct comparison against stock. I will be using it with the 3000cfm fan.
I was originally running a thermo (with a proper shroud) using a hks fan controller, with relatively good luck. Only went back to stock as fan controller shat itself.
Keep in mind I’m the kinda guy that cruises round the Bunnings car park, not the track haha.
  • Like 1
Definitely keen on the results!
A good test is to park the car stationary and leave the A/C on for a good 15 minutes and see what your coolant temps are like.
On a 36 degree (Celsius for those Americans reading) with the A/C on for a good 15 minutes my coolant temp would sit about 99 ~ 103 degrees, oil temp about 105 degrees. As soon as I drove for 15 seconds, that would drop back into the low 90s.
Without A/C on at all, when stationary the water would stay in the low 90s, once moving mid to high 80s.
Funny enough, when I'm giving it a hard time at the track (i.e. going around a circuit not down a drag strip) water temps generally don't move far from mid to high 80s (I suppose there's heaps of air being forced in from the front of the car).
Maybe you should “invest” in the new PRP RB electric water pump… might also help the belt spitting issue..
I've donated enough to the Nissan car gods lol...
The more I spend on this shit box, the less money I have to put towards a fast, stock, modern car.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
