35 minutes ago, Murray_Calavera said:
What's the news?
The ic7 will be firmware updated to allow 2-way CAN communication allowing additional inputs for the ECU. It will also be a master device now, so I believe it can act as a controller for the PDM. You can also customise logos etc.
  • Like 2
Pretty much no need for an I/O expanded if you have a dash.
Also, there may be a new Haltech dash coming in the future, I hope they update the housing lol.
That's the only reason why I didn't buy an IC-7, I know it's silly, sure it's ugly but the car itself is pretty ugly too LOL.
Yeah, I think they are bringing out a bigger display. I think a 10”??
the ability to programme the buttons on the display is pretty good too.
One can hope, if not I'll just get an IC-7 and stop sooking.
Loaded up the latest firmware, oh wow... went for a drive and it's like I've setup Alpha-N and MAP compensation. I thought the transient table I built was good, but wow... this just brought it to another level.
@R3N3 this is how I make the car brap lol.. sounds better than rotational idle
Nice little timing hole lol
And for the idle control you want it to not much between -50 ~ -100 RPM
Awesome! I will compare the sound. I ended up dialling in the launch and rotational idle 100% many bangs and flames were had. Although I’m a little worried about my stock oil pump gears…
  • Haha 1
1 minute ago, Dose Pipe Sutututu said:
Didn't you want to build a new motor? LOL.
Haha, true! The plan is to switch out a working motor with another working and better motor…
Last time @admS15 used his launch control, he lost a turbine LOL.
On 08/10/2023 at 1:38 PM, Dose Pipe Sutututu said:
Washed the shit box, forth wash since the start of 2021 when the respray was done.
As much as you like to complain about it, your car is a looker! Is this photo with new tints? Which ones did you end up going with?
It's on my list of things to do, though not at the top. Being able to see nothing at all out of the windows when it's dark and wet outside gets old very quickly.
I work in IT, complaining is a prerequisite LOL.
I went with a legal 35% tint, it's some ceramic bullshit (apparently good?). Got it done by Tint a Car in Moorebank.
  • Like 1
Haha, fair enough. Yeah ceramic is meant to be better with keeping off heat. Or so I learned doing all of five minutes of research.
But for some reason the extra photos you included in your post that show the new tint don't load.
    • And now the washer bottle looks like an orphan. You're going to have to spend money on a wrinkle black painted fabbed ally one of those. Oh, and the brake MC res. That won't look any good after you've gotten rid of the washer bottle. You going to need to go back to work to keep up with this?
    • You're going to need all that and more to keep them from rubbing at the rear anyway, is my guess.
    • Looking at it now the battery clamp needs some love..  LOL One day, but not tomorrow, tomorrow I'm strictly a spectator, the only testing for me tomorrow will be on the coffee and food at the Cafe
    • I purchased some (used but new to me) Yokohama A050 Mediums to try out for the first time and fitted them up to one of my sets of Rays TE Fortesst's. Sizes are 235/45R17 front and 255/40R17 rear. They are very chonky compared to the same sized AD09 on the same sized rim. Some fiddling will be needed to make them fit. How much camber do these like as a general rule? I imagine more than the rear camber of -1.5' I typically run. So my plan is to target -3.8 front and -2 rear
    • If you want to test it under temperature, I think you should enter the One Raceway day tomorrow with Duncan!
