4 hours ago, r32-25t said:
Did you get the 230mm version?
I’ve got the solid center version and it’s a dream to drive
Yeah same as yours, however just sprung centre.
Trying to prolong the box going KAPOW as long as possible lol
  • Like 1
On 11/26/2024 at 10:18 PM, Dose Pipe Sutututu said:
Been needing a new clutch for a while, but holding off because of life tingz and adulting.
But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799).
Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them).
Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
I used to daily mine with a 6 puck button clutch. It drove (to me) like a factory clutch. Roll it off the mark all like normal, no jerking, no bucking.
Hilariously no one else could drive it without dialling up about 3,000rpm and chirping the tyres off the mark, or stalling it.
It's all about getting used to it.
  • Like 1
Haha yep, everyone stalls mine. Even catches me off guard when I'm trying to reverse up my driveway into the driveway with a decline.
Hoping the twin plate sprung organic is a bit more forgiving for my old and tired body/legs/pelvis.
  • Like 1
Fark this... mental health day it is tomorrow.
Booked Luddenham lol
Is the clutch fked? yep
Do I need to fix that in tank venturi? yep
Will I do any of the above? No
  • Like 1
  • Haha 1
Yeah boiiiiiii
PB the karnt, then lost an IC clamp. Was also warned about go sideways 😂
He said he understands the track is hot and tyres let go in the heat.
Called it a day 4th session, came on the throttle on Lap 2 and lost boost. No idea where the passenger side IC Bluetoothed to, and it was getting quite hot so called it quits.
Waited for the other boys then we ended up at the pub for 3 hours lol.
My mate in the R33 shit box managed a 59s on his first track experience at Luddenham.
  • Like 7
6 hours ago, Milkmun said:
How much work to get you in the 55s? Or just more seat time?
I think just better tyres, I'm just on Hankook RS-4 tyres at the moment, which aren't really meant for the track.
Also, been mucking around with my suspension for sometime now and I'm really happy bow neutral it is. Car doesn't want to just oversteer or understeer like it did years ago.
Time to put on proper tyres one day and see what the shit box can do at SMSP, One Raceway and Luddenham again.
  • Like 1
Yeah, you'll never get a reasonable time without spending on tyres, they ware worth more than all the other mods put together for lap times.
How's the garmin going? It is difficult to get data logging into the new car (because must retain standard ECU for tuning which can't do lap logging so need separate systems nekmennit), was thinking about using one of those in the meantime
It's great, fantastic bit of kit for the novice like me.
One thing it doesn't do, as @No Crust Racing pointed out before, is capture CANbus data. Would be great to get additional data from the car to overlay.
I'll download the video from my 56s for a laugh soon.
  • Like 1
yeah basic OBD data would be nice, and cheap electronically to add, might be coming in future.
unfortunately in nissan at least, only a small subset is on the OBD can and all the interesting stuff like boost or oil pressure is on a proprietary CAN
  • Like 1
It's easy to tap to the other CAN networks, and in addition, most of the stuff you'd want could be obtained by querying the data over UDS on the network available on the OBD2 port. That said, it's much nicer to just listen on the appropriate network to data that's being streamed rather than querying in steps using OBD2 or UDS.
10 hours ago, niZmO_Man said:
what are you going to get?
I think depending how much left over cash I have after all the kids and wife (daycare, extra curriculum activities, toys, and whatever they drain from my account, wife's spending, etc.) I might go for the Advan A052 OR if the bank account says no, then Nankang CR-S.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
