On 26/04/2025 at 10:14 AM, Dose Pipe Sutututu said:
the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
Hmpf, that doesn't sound great. That makes it feel like it might be better to put the money towards a track day instead. It didn't seem that bad the two years before.
On 26/04/2025 at 9:53 AM, The Bogan said:
Is there an actual website thingie for peoples who don't have Facebooks?
As Brett mentioned it'll be on the roll racing website. Sale starts 6pm on Wednesday. Tickets may sell out quickly so if you want to go, set an alarm and get them at that time :)
All I want to do is be a spectator and check out the cars in the show and shine
Oh, right. In that case there is no rush. It's the car entries that are quite limited and can sell out quickly.
  • Like 1
That's correct, suits my requirements a bit better.
Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
  • Like 1
Great read about manifold design, twin scroll with the division all the way to the wastegate seat/fire ring
https://www.facebook.com/story.php?story_fbid=1088497013319763&id=100064784224104
This is why I bought a Sinco manifold for my shit box and not a 6Boost due to wastegate design.
  • Like 1
1 hour ago, r32-25t said:
Or just do it properly and get a manifold with 2 gates
how is a manifold with the pulses split all the way to the gate seat any different?
Same outcome.
Just need to remember how lazy exhaust gasses are, it's travelled down the runners, into the collector and up through a divided wastegate path, even if it's not a 100% divided seal at the wastegate piston/valve, it's not going to travel all the way up, down, then back into the opposing cylinders.
Anyhow, each to their own, nothing wrong with twin wastegates. I just prefer 1x huge one.
Actually, that's what that post is saying is happening, with only the LAST 10mm to the wastegate flange not divided.
A whole single centimetre is what they're claiming caused that change.
However, I haven't actually punched the numbers in etc to do any mafs, but they're talking 26PSi + of boost, and it taking nearly 2 seconds longer to climb a further 200rpm... Yep, it was in 4th gear, but, say that car does 2800RPM at 100km/h, they're talking a car making 26PSi, is taking an additional nearly 2 seconds to go from 128km/h, to 135km/h... That's pretty extreme to me.
Also interesting as you scroll down through the comments and I started reading there was someone who's done very similar testing, on a hub dyno, back to back without even pulling car off the hub dyno, and barely saw any change what so ever on a stupid powered car.
I was more referring to Brett's 100% fit comment, where there isn't a perfect seal between the wastegate piston/valve.
I do not believe at that point there would be a discernible difference in spool/engine efficiency.
Where as the usual 6Boost style of "twin scroll" which doesn't divide the pulses to the wastegate versus something like a Sinco twin scroll, which is split all the way to the wastegate piston/valve, you'll definitely see a difference.
I guess the question becomes, if 10mm gives 1.7 seconds of spool difference, what does 1mm give?
Because you'll need a gap. Even if you're the world's best fabricator and can get that fitment PERFECT, you have two metal surfaces about to heat up and expand. So you need to leave a gap. Realistically, they're likely to leave a couple of mm for most fabricators, so how bad is 5mm compared to 10mm? Or more so, how much worse is 5mm vs twin gated?
But then, if it merging before the gate is bad and hurts spool, I wonder, what would happen if you keep both gates completely separated in their own exhaust systems too?
Would there be any benefit anywhere to keeping them fully split?
Would there be a benefit like with an NA V engine at running an X pipe or a H pipe?
35 minutes ago, MBS206 said:
what does 1mm give?
My guess? Almost perfect separation. The pressure pulses would bleed across, but because they have to squeeze through the gap, they will be substantially attenuated.
Given most twin gates are plumbed back to atmosphere..... I would say that experiment is well understood. But in reality, it would make no difference to spool at all, if they are 2 completely separated gates. What happens downstrema of them will not affect spool at all.
  • Like 1
I'm thinking beyond spool. The claim in this alone shows evidence for spool only. But spool is one thing, what about the rest of our power band?
And if we say 1mm is negligible, what is the relationship like for the gap? Is it linear? Exponential? Linear to a point and then it just doesn't matter anymore and stops getting worse?
These are just all the questions... I don't know the answers definitively either.
I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?.
This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious.
And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
Actually, I'd argue that that is exactly when having the wastegate/scroll isolation correct would show the most benefit.
  • Like 1
In other news, my shit box R33 is Gregged.
I kid you not, 3 months ago it drove perfectly fine, parked it and it sat on the trickle charger for about 2.5 months. A few weeks ago, noticed the charger stopped working.
Oh wells, 15 years out of a CTEK charger, across 3x shit box JDMs (and other dailies) you've done well.
Went to try start the car today, nothing. Thought, yeah ok, let's get the jumper leads on.
This is where shit escalated lol... Initially popped on the leads and noticed a great deal of sparks, not to worry. Let's triple check shit and try again, yep same. Thought perhaps was just an initial current draw from the 2x audio amplifiers, etc. nope, leads got warm and the fuse box jump point started to GLOW! 🥲
Luckily the Tiguan wasn't on, I can't imagine what Christmas lights combination would have appeared on the dash if the motor was running.
Anyhow, hastily gave up and messaged Brett for a laugh, or commiserate whatever you want to call it.
Skyline (Shitbox) Lyfe 😂
  • Sad 1
34 minutes ago, GTSBoy said:
Test actual voltage on battery. It's probably way low and possibly got a shorted cell. Something that might explain everything in your report.
Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place.
Sparks...
I suspect the following:
  • Alternator has decided to kill itself
  • Starter has decided to kill itself
I'll recharge the battery, then unplug both, and go from there.
The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight.
https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
